Skunk2 Pro C vs. Pro S Tech Video
We've been getting alot of questions about the differences between our coil overs and how it works. There are still a few of you guys who aren't too sure about the difference between the Pro C and Pro S Coilovers so we made a video to show you the Benefits of the Pro C threaded shock body vs. the Pro S standard coil over. This should give you a better understanding of how to lower your car on the Pro C coil over with out effecting spring preload and losing shock travel thus giving you maximum travel while dropping your car to the floor.
For more information you can visit:
http://www.skunk2.com/skunk2_videos.php?video_categoryName=Tech+%2F+Inst all
so the pro c you have to pretty much take you bottom half of you suspention apart to ajust them? unlike the pro s where you can just lift the car and ajust the perch to where you want, but if i had to choose one i would go with the pro C FTW
entire coilover until your desired drop is found. then tighten the nut.
NineHotel
06-10-2009 05:51 AM
skunk2.com
34
01-22-2009 04:14 PM
skunk2tony
19
02-15-2008 03:35 PM
