Sound Deadening For Suspension
come on, you're driving around a modded honda in the import mod
capital of the entire America's.
i use to eat over at SHIN SEN GUMI all the time. those karate folks
scare me sometimes with their loud voices. WAT WOULD YOU LIKE
SIR?!!
umm...a little piece and quiet would be nice to go with my Hakata Ramen...
SIR?!!
HAhahah but yeah, it's fixed. the sounds gone, cars dropped, all good. hahaha thanks man.
Shin Sen Gumi in Torrance? Gardena? ahhhh ramen... good stuff
OoOoooO I go there too. hahaha niice. I live a couple minutes away from there. I'm near 182nd and western.
skunk2 clank
soooooooooo i just installed my skunk2 springs today after the hell the axle gave me yesterday from popping out , but finally got it done today and all i have to say is damn............ <the back clanking> sound is very loud and annoyin hahaha i rechecked to make sure everything was adjusted and tightened up should i just give it a few weeks or days for them to adjust from all the driving around or should i be looking for something else ??
I have had my SKUNK2's on for about 3,000 miles and mine clank too! Rechecked everything.....no luck. It is annoying .
tonyd
if you're certain that your spring orientation is correct might want
to add some spiral cable wraps over every other coil that are closer
together. you can get some at radioshack.
if it's metal to metal noise, you might be experiencing spring chatter
over moderate sized bumps.
RadioShack.com - Cables, Parts & Connectors: Wire & cable management: Wire ties & wraps: 10-Ft. 3/8" Spiral Cable Wrap
Haven't seen your app but many others. Here's what we've learned to look for:
1. clunking is often the coil springs rotating on the shock strut. Check to see if your spring is truly seated in the bottom coil seat. If there is ANY clearance at all the spring is banging the stop on the seat as it compresses and rebounds. When we install springs we always insure that the spring is 'wound' tight against the stop when the uppere seat is installed. To verify if you can see or feel clearance put a thin strip of hard rubber or shim between the spring end and seat stop and see if it reduces the clunking. No it won't last long.
2. The Fit suspension has somecomponents that are in close proximity, notably the antisway bar. We've had luck putting tygon tubing around the bar where its close to the arms, And we have found an antisway bar bracket that was nottightened securely around the bar. Yeah, more tygon tubing. (easily obtained at local Lowes.)
Good luck.
Good luck.
Good luck.
Good luck.
tonyd
ommegga
17
12-09-2018 06:03 AM
