sway bar endlink
sway bar endlink
i need a front sway bar endlink that i can adj. the length
after installing BE sway bar, i felt that it is rubbing on the lower arm, and the T1R end link that came with the t1r coilover arn't adjestable.
so i need one that i can make shorter, bringing the sway bar higher from the lower swing arm.
any help would be great
thanks
thanks
You could take the endlinks you have to a machine shop and get them cut and threaded in the middle and joined with a threaded coupler. That would do the same thing as the Powergrid endlinks but probably cheaper.
igarage
07-30-2008 12:02 AM
