N1 Concept's K20A jazz.
Old 07-21-2006 | 01:37 PM
gettinafit's Avatar
I will do the K20 Swap once N1 Concepts comes out with a kit, IF they plan to make a sell-able KIT and not just cut and weld!
R&D on the East coast and you can use my car!
  #42
Old 07-21-2006 | 01:39 PM
gettinafit's Avatar
got any close up pics of mounting/ welding or just full engine pic in car!?
  #43
Old 07-22-2006 | 06:22 AM
blackgd3's Avatar
Senior Member
You're really excited huh? Once you get yours done, you'll be one of the first to show everyone the potential of the honda fit I'm really excited too!
  #44
Old 07-22-2006 | 10:04 AM
aallbbeerrtttttt's Avatar
they use full engine mounts, no cutting or welding of the frame rail is necessary
just wait a while and there will be something for the USDM guys
  #45
Old 07-22-2006 | 11:04 AM
gettinafit's Avatar
Awesome! Patiently waiting...... i feel like a waiting Fit owner.......
  #46
Old 07-24-2006 | 11:31 AM
blackgd3's Avatar
Senior Member
Any updates from n1?
  #47
Old 08-01-2006 | 01:31 AM
conekiller's Avatar
Hasport Mounts
The Hasport Mounts are finished and as usual they look great, the K20 swap is really not that hard if you use the correct parts , the USDM fit requires a very minor chassis modification but it can be done with a drill , but it allows for the correct driveshaft angles to be acheived as well as proper weight distribution over the front wheels. the really nice thing about the hasport mounts is that it allows for just a k20 swap or an entire front subframe swap as well so for future widebody or suspension upgrades you dont need to remount the engine. We are building two of the baddest fits on the planet and it will be released @ SEMA I may post some teaser pics soon.. if you want to get a set of mounts check out http://www.hasport.com/
For engine swap tech relating to the use of Hasport products, please call 602.470.0065
  #48
Old 08-01-2006 | 01:58 AM
Ricepuddin's Avatar
Father of the Wasteland
EDIT: NVM I read something wrong
  #49
Old 08-01-2006 | 07:33 AM
blackgd3's Avatar
Senior Member
Cool!! More k20 fits!
  #50
Old 08-01-2006 | 10:47 AM
gettinafit's Avatar
I went to their website, found nothing about Fit K20................
  #51
Old 08-01-2006 | 03:09 PM
Meister19's Avatar
wow this is definately amazing. Sounds so mean too
  #52
Old 08-01-2006 | 03:15 PM
Ricepuddin's Avatar
I think he ment after SEMA
  #53
Old 08-08-2006 | 09:47 PM
fitbum's Avatar
what is the difference in chasis between usdm and jdm fit? will the k20 mounts be designed to accomodate jdm chasis as well for us jdm fit k20 wanabe owners out there
  #54
Old 08-08-2006 | 10:34 PM
conekiller's Avatar
there are a lot of issues with the RHD fits and the K20. the placement of the engine puts a lot of angle on the DS but you have to for the electric steering to clear the differential.
  #55
Old 08-09-2006 | 07:34 AM
blackgd3's Avatar
Senior Member
I'm interested in knowing that too
  #56
Old 08-09-2006 | 01:05 PM
conekiller's Avatar
New thread
Ill open a new thread on the hasport Mounts
  #57
Old 08-09-2006 | 04:18 PM
fitbum's Avatar
sounds good _b
  #58
Old 08-14-2006 | 02:55 PM
N1Concepts's Avatar
actually, the RHD Fit doesn't have any issues at all w/ the electronic steering rack and the drive shafts on ours have the same angle as the stock Fit motor. the steering rack is on the right side and the K20 transmission/differential is on the left side. the USDM/LHD Fit has some issues clearing the steering column b/c the column is on the same side as the tranny.
  #59
Old 11-11-2006 | 07:14 PM
ghettoracer's Avatar
Originally Posted by touge_tina
is this fit drivable? ive been hearing that yes it is possible to swap a k20 into the fit but it compramises the handling by lots?
Unfortunately I've never driven a stock JDM nor USDM Fit, so I can't compare stock handling vs. K20A Fit. But overall I'm really impressed with the N1 K20A Fit's handling even though there was practically zero suspension development time. We just bolted up the HKS HyperMax suspension 1 day before the Time Attack and went. Next morning, a quick check with toe plates at the track showed over 2" toe in! By lunch time we finally got it aligned. During shakedown session we immediately posted 2nd fastest lap time in class (thanks to K20A's good straight line speed, NO THANKS to the bone stock brakes), and with just 2 more laps we dropped 2 seconds good enough for the class win.
K20A Fit shows excellent potential and Norman and I discussed the possiblity of taking it to the next level. This yellow wide body Fit is a show car after all, N1 is considering building a road race Fit now. :-)
  #60
Old 11-12-2006 | 07:45 PM
Ricepuddin's Avatar
I hope you guys do. Maybe when im back in VA ill see it at VIR or MIR.
Quick Reply: N1 Concept's K20A jazz.
