I want eveyones opinions, what looks best
Vivid blue pearl with lamin-x
Vivid blue pearl with clear lenses
Nighthawk black pearl with lamin-x
Nighthawk black pearl with clear lenses
or flat black (not pictured) trying to make them match the finish of the black plastic lower grill.
Haha you weren't kidding when you said you were a perfectionist.
I forgot which one I used, I know for sure I redid one of them at work the next day with a can of black rustoleum we had. Both look the same to me, and both pretty much match the lower grill. You could always just respray the lower grill too if you were really concerned.
But yeah, I guess I could spray the lower grill to match, but then it wouldn't be the original. :b
flat black with urethane flex agents=
Its something that is mixed in with the paint before its sprayed, urethane parts are very flexible, you can twist it up and it will go back to its shape. Your paint with shatter off if its twisted up like that, the cure for that is adding flex agents to the paint, its added into the paint and then when its sprayed the paint has a certain amount of flexibility to it so it wont crack and split.
Any reputable body shop that has delt with body kits and what not could do it no problem. The flex agent takes away some of the flatness of the color and makes it a almost a semi-gloss kinda color.
edit - "The flex agent takes away some of the flatness of the color and makes it a almost a semi-gloss kinda color." <---- when the color is "flat" to begin with, such as flat black in my case.
