Fit Projector Headlight
yea man... get those and retro some HID projectors in and it'd be cheaper than buying the OEM ones and retro'ing. Really wish depo would release it here in the states, just need to flip that damn cut off line so its on the side.
unfortunately, the USDM or North American spec fits have slightly longer headlights - our bumpers and fenders are also different from yours. So, either depo needs to make USDM ones, or I'd have to get JDM fenders and bumpers to accomodate these!
According to one of my friends, the size of front bonnet, headlamps, tail lamps, 3rd brake light and other stuff are exactly the same as the Fit / JAzz in Hong Kong, Japan, and Thailand except the front and back bumper is bigger in size.
So except the front grille, all other accessories are compactible
Hi bros, I measured the size of the head lamp for your reference. The straight side (close to the front bonnet side) is around 52 to 53cm. So now you can make sure the headlamp in US is the same as the ones from Japan, HK, and Taiwan.
Thanks!
Thanks!
Hows the projection of the headlight, I know that a lot of projector headlights don't focus on optics, they focus more on looks and design. Does it point like a waffle ice cream cone? or wide like it should?
It won't be spot as sharp as a waffle cone but it's like a light cylinder beam which is more spot focus to the front when comparing with normal headlamp. It's more recognization if you use HID with this projector headlamp.
nicoli
03-25-2015 12:27 AM
07, 2007, aftermarket, depo, fit, fitjazz, head, headlight, headlights, honda, manila, projector, projectors, sale, size
