Hasport K20/K24 Mounts
#41
Yeah, I wonder what's up with the delay
#48
Anyone know
Well im about to get my Fit and im picking up my k20a2 W/ITB's from a local. Has anyone on the boards done the swap?? How hard is it. i have swaped motors in civics and things of that nature but this is a new car so i dont know how it will go.
#50
hasport makes a kit....not sure if its available yet.
theres a few people that have done it (shops) so hopefully they can chime in on this and give you a few pointers. a big thing is the RSX k20 is traditional cable throttle system. the Fit is DBW so a retro fit of some sort will be needed to make it work properly.
both the L15 and the K20 spin the same way (unlike the 90-00 civics) so thats a slight bit of good news. i have heard there will be some cutting of the engine bay to make the mounts fit right and have it all line up. other than that im not much help.
#51
#53
Good luck with splicing those wires to get those paddle shifters working.
#56
We are working on the kit to try to release it in the next month or two. The wiring will be unique in that both the Fit and K-series ECU will run concurrently. It makes the swap more expensive, but you will have full use of the dash and full control of the ECU.
These newer cars are problematic with the can-bus communication and some of the advanced systems controls. Takes time.
brian g
Hasport Performance, Inc.
brian g
#57
Damn this is good to hear/read...I was giving up on my swap and planning to sell my k20r then go with the t1r turbo. Thank you and god-speed with the process.
brian g
brian g
#58
brian g
brian g
#59
Brian,
Do you have just the mounts?. 90% of my dash is going to be aftermarket guages anyhow. I'm a car audio/security so wiring is a non-issue. I just want to get the K24 in there without cutting or hacking.
brian g
brian g
