VTEC Light for USDM FIT Completed!
#101
So no one's really made a plug-n-play kit for this yet, have they? I'd like to add one to that blank to the left of the steering wheel, personally.
Those that have had them for a while now haven't had any troubles with tapping the wire, with or without the relay, have they?
#103
Hey is that LED light really bright while driving at night? Is it adjustable wth the rest of the instrument cluster?
I like that it closely matches the stock blue color but I turn my instrument display way down so that it's harder to see me through the window tint at night..."tactical driving"!
#106
"Home Depot Ram Air"? I am afraid to ask what that is all about.
#107
can someone do a real simple DIY version as to which
wires to tap on the 08's ECU? i looked through the entire
thread but unclear as to which wire to tap.
i want to just do a straight LED tap and use a lower
mcd.
thanks.
mcd.
thanks.
#108
Any reason you can't just wire in a switch on the VTEC? Since you're in there tapping the wire for the LED, why not run a couple more to a switch so you can turn the VTEC off? That would be pretty handy for highway cruising.
#109
Hey guys, i just finished my vtec light!!!, its awsome, i put the led to the left by the power mirror swich in the blank panel, looks great at night.
i wouldn't try putting a switch in the vtec line, when the computer commands vtec, it expects things to happen, and if they dont, your probably going to see dtc's
2 mods in one 3 days, a/c mod, and the vtec light,
good week.
good week.
#113
yes i think that has been mentioned before, however most people do not want to remove and dissassemble, and modify the cluster, it is complicated, and is a very expensive part to replace if you screw up.
that would be cool though
#116
its like blue then when vtec hits it turns red
that would be cool hahaha
#118
Bi-colour red/blue LED: Bicolor LED - Blue / Red LED N500TBR4D
edit: Anyone taken the cluster apart? How hard is it?
