need help in keyless install!!!
Old 05-18-2011 | 11:46 PM
dthdabomb89's Avatar
i am trying to install a keyless entry/alarm into my 07 base fit. The wire guides online say the constant power wire is white and it should be in the ignition harness by the fuse box. i cannot find the harness out of all of them or a solid white wire.
can anyone help me find the right wires to splice into!
also i cannot find the "purple and green" door trigger wires...
i have spent almost a day on this with no luck, even spent forever googling...
i appreciate it!!!
Old 05-21-2011 | 07:11 PM
lashlee's Avatar
When it comes to finding wires (or a given harness) I would start with where the harness terminates. In your case, start at the ignition switch and follow the harness down the column to where it plugs in to the back side of the fuse block. You'll have to pull the lower dash piece and column cover. Same with the door trigger wires, look for the wiring coming from the dome light plunger in the pillar. They should be in the kick panel area. In older Accords (94-02) the door lock wires were in a plug right next to the fuse block. The door triggers were in different spots.
I've a tool called a "probe" or "power probe" that tells me if a wire has voltage or is grounded that helps when it comes to finding wires for alarm or keyless installs. This way you don't necessarily have to rely on what the net has listed for a given car.
Old 05-23-2011 | 11:16 PM
thank you so much. i followed the wires from the ignition and found all that i need. got everything all plugged up right and the keyless entry doesnt work. must be a dead one because i know i plugged it into a battery wire but he things didnt even light up saying on.
so, i just went ahead and bought the oem harness keyless entry from collegehills honda.
i locked my only key in my car recently and from trying to unlock the door somehow my driverside key hole is messed up and i cant get in on that side so keyless right now is a must!
cuban8
08-15-2018 09:13 AM
smitch
10-17-2011 11:28 AM
Sahilchaddha
10-05-2011 04:57 PM
cycoxtr
08-06-2008 02:04 PM
smeister
07-07-2006 04:51 PM
Quick Reply: need help in keyless install!!!
