Coming soon! DIY Auxiliary for Base Fit
Old 06-15-2006, 06:57 AM
smeister's Avatar
Originally Posted by FitCustomer
Metra sells a 20 pin radio harness as part number 70-1722:
http://www.metraonline.com/_assets/m...NST70-1722.pdf
Metra also has the 17 pin harness as part number 71-1722:
http://www.metraonline.com/_assets/m...NST71-1722.pdf
But these plug into the vehicle harness, not the radio.
One other part is Metra #71-1721 which plugs into 2005 CIVIC radio, but doesn't look
like the pin rows are offset as in the pictures above.
What are you going to use to connect to the 6 pins (in the 20-pin input)?
I'll figure out what I will use today when I talk to my EE. I'll keep you posted.
Old 06-15-2006, 06:04 PM
hatchgeek's Avatar
Not that I would ever be able to do this myself once you fellas have it figured out, it is nice to know there is hope. Please keep us updated to the progress.
Old 06-16-2006, 04:32 AM
Papichat's Avatar
BUMP!! Post a complete write-up with pics ASAP.
Old 06-16-2006, 11:23 AM
smeister's Avatar
I might have time to do a ghetto install later tonight just to make sure it works and then get the correct harness etc later on. I'll keep you guys posted.
Old 06-17-2006, 10:47 AM
lagunafit's Avatar
Does the Music Link use that connection point as well? In other words, if I have Music Link installed, can I still do this AUX jack workaround that you are working on?
Old 06-17-2006, 05:34 PM
Gabes Dad's Avatar
No, the the Music Link used the 14 pin jack that is not labeled in the previous diagrams. It is essentially a CD-changer input. The device smeister found for around $100 uses that jack and is made for hooking up Sony CD changers, it just also happens to have RCA inputs. So you could have the AUX hookup and the Music Link. But from what I hear, the music link isn't really worth it - just use the aux input. So you could have a CD changer and an AUX input also.
Old 06-17-2006, 06:39 PM
lagunafit's Avatar
Well, I actually had the MusicLink installed already- it's O.K., but I'd like to be able to use my older iPod and my iPod shuffle and not deal with the difficult interface that MusicLink makes you go through. So MusicLink goes into the unmarked 14-pin connection, I got that- which does the Aux jack wire go into?
Old 06-18-2006, 08:23 AM
Gabes Dad's Avatar
The 20-pin connector B shown in the diagrams.
Old 06-19-2006, 10:30 PM
timster's Avatar
Is the power that's in the harness only on with the Ignition switch?
Any recommendations on a close place to tap always-on 12v power?
Thanks!
Old 06-27-2006, 08:35 PM
FitCustomer's Avatar
Hey Smeister,
Did you get a get a 20-pin plug to wire up the AUX jack? Does it work?
Any Pics of your installation?
Old 06-28-2006, 12:47 PM
smeister's Avatar
Hey Smeister,
I am not too worried if it will work or not. I havent had time to install it yet. I have the cable and 3.5mm cable ready. I am probably going to soder the connections on it this week since I don't have the harness needed. I'll keep you all updated.
I did get to install my components and an amp which is a pretty nice upgrade to the stock speakers even with the stock headunit using a line output converter.
  #32
Old 06-28-2006, 02:48 PM
What are you going to solder? Are you going to solder the 3.5mm headjack/AUX port cable
directly to the 20-pin connector on the Honda head unit?
  #33
Old 06-29-2006, 06:04 PM
smeister's Avatar
I'll soder the wires going from the 3.5mm to the back of the headunit 20-pin connection directly instead of using a harness. I'll try to do it tomorrow.
  #34
Old 06-29-2006, 06:26 PM
aziatiklover's Avatar
Master FitFreaker
very nice man
  #35
Old 07-08-2006, 04:17 PM
smeister's Avatar
So, I did it. I ended up sodering the wires to the headunit instead of using pins. That way I dont have to worry about them coming loose. I'll have pics up later tonight. It was very easy to wire up once Gabes Dad hooked me up with the diagrams. I couldnt have done it without them. Thanks!
  #36
Old 03-15-2007, 01:59 AM
Vampgrrl's Avatar
So there is no direct plug and play match for the base audio AUX back of the headunit to the Sport AUX wire?
I'm not too interested in trying to solder anything together....unless someone comes up with an easier solution, MusicLink for me I guess.
deevergote
06-10-2012 10:41 AM
dthdabomb89
05-13-2010 05:18 PM
kkim
05-29-2009 07:28 PM
apachesurfer
03-11-2008 09:49 PM
cycoxtr
01-13-2007 08:31 PM
Quick Reply: Coming soon! DIY Auxiliary for Base Fit
