silver ring around auto shift shaft
i was stupid last week and let one of those leaf air freshners be wrapped around the shift boot and it took some paint off the silver ring after 2 days
leaf air freshner on silver ring FTL!
-Ricky
It's really not that bad, I take them out a lot I can probably do it in 3 min. It's just 2 clips down at the front, 2 screws at the back, remove the cover under the e-brake, lift the console, unplug cig lighter plug and aux plug up front and you can removed the console.
Is there an easy way to re-install the clips at the front. They were a real PITA to put back in... I had to put my hand behind the console to separate the 2 prongs, it took me 10 minutes just to get those to lock.
cajunpedaler
10-20-2015 03:42 PM
