shift boots
shift boots
im looking to replace the stock shift boot i have for a leather one. i couldnt find anything on it. would a shift boot from integra t-r or civic t-r fit in the fit? i know that the mugen shift boot because aj racing has it in their fit. looking to get a skunk2 or blox shift knob with it. im new to this so any help would be great.
eBay Motors: JDM Genuine Honda Integra type R DC2 Shift boot NEW Red (item 120138489142 end time Jul-06-07 09:59:35 PDT)
or
eBay Motors: JDM Honda Civic type R EK9 Shift boot NEW red (item 120138489156 end time Jul-06-07 09:59:38 PDT)
or
I assume you use the stock ring? I haven't seen under the shifter so I'm unsure how the boot would mount. I'm guessing similar to my integra with a frame that boot wraps around at the bottom?
there was someone that did a DIY here, but its actually pretty easy. The Fit has less "tabs" on the bottom than the rsx or Si boot, however if you use most of them it should be ok. Theres 3 screws underneath as well (not for the boot) but I used those to hold it in place since I used a DC2 boot with no tabs on the bottom.
413FitMurtz
01-30-2016 12:35 PM
