MSN Dashhawk
MSN Dashhawk
MSD has just come out with a new scangauge-type device called the Dashhawk. It's $300 and I'm still trying to figure out if it is compatible with the Fit, but I wanted to post it here to let everyone know about it.
DashHawk Vehicle Information Display
I am nowhere near my car, but this is from the site:
My vehicle is not on the supported list. Is it CAN compliant?
If you vehicle is not listed in the supported vehicles page, all is not lost! There are many vehicles being added/tested every day and it is hard to capture them all and keep them up to date, so a good way to see if your car has a CAN bus is the following:
- Locate the OBDII connector. It is under the dash on the driver’s side of the vehicle, often either under the steering wheel or tucked up next to the driver’s side kick panel.
- Look carefully at the plug with a flash light or other bright light source. If pins 6 and 14 have metal pins in them (i.e. are “populated”) then the vehicle has a CAN bus and DashHawk will most likely work with this vehicle.
User1
06-12-2019 12:56 PM
