Door Trim Kits, questions,answers, photos
Old 07-23-2006 | 01:58 PM
leonine's Avatar
Just finished installing them this morning. They look awesome! Much cleaner than stickers that go on top IMO.
  #42
Old 07-23-2006 | 05:56 PM
leonine's Avatar
Did mine myself
Much cleaner (no gap) and a hell of a lot less $$$. Found spray paint that is very similar to VBP. Painted my intake manifold cover and had some left over.
  #43
Old 07-23-2006 | 06:34 PM
smeister's Avatar
Nice paint job on the interior pieces!
  #44
Old 07-23-2006 | 07:20 PM
leonine's Avatar
Thanks! Kind of a small pain in the ass to get them off but well worth it.
  #45
Old 07-23-2006 | 09:18 PM
aziatiklover's Avatar
Master FitFreaker
very nice paint job man... I got lazy so I bought the actually oem trim kit lol
  #46
Old 07-23-2006 | 10:21 PM
leonine's Avatar
Thanks. The dealer was tryin to jerk me around saying they were an option on the vehicle that i had to buy. BS.
Next i want to paint the speaker enclosures...that would be pimpin IMO. Have to see how easy they come out, if they do at all.
  #47
Old 07-24-2006 | 10:33 PM
leonine's Avatar
Originally Posted by oOo LinDa
Just noticed that the red trim does not cover the WHOLE console on the drivers front door. Wack IMO. I'm glad i did it myself. Looks like it came that way from the factory.
  #48
Old 07-24-2006 | 11:24 PM
Mugen_Dom's Avatar
What kind of paint did you use?
  #49
Old 07-24-2006 | 11:52 PM
leonine's Avatar
Plastikote metal flake part #311. Got it at Carquest.
http://img86.imageshack.us/img86/3193/img1558wp6.jpg
  #50
Old 07-26-2006 | 02:35 PM
tershel's Avatar
hey leonine:
how did you remove the interior pieces( one for the door pieces).
im having a hard time removing as i dont want to damage anything.
any help or hints on how to remove them.
thanks.
i already bought the paint...just a matter of taking these pieces off.
  #51
Old 07-26-2006 | 03:24 PM
leonine's Avatar
Originally Posted by tershel
hey leonine:
thanks.
Hey Tershel,
Looking at the pic below for reference, lets make the following assumptions:
right is the right side of pic; left is left side of pic.
back is towards the window; front is away from the window.
so right/front would be the right side of pic away from the window.
1) starting at the right/front you will insert a tiny flat head (put a cloth over it if you are worried about scratching the trim) between the console trim and the door arm rest. Pry out and to your right. You will see that there is a kind of plastic lip that connects the two together. The lip is part of the door arm rest and it slides into the console trim.
2) once that is done, place the flat tip screwdriver inbetween the console trim and the arm rest starting at the right/front and move towards the left front, pulling outwards. This will separate the console trim from the arm rest.
3) look underneath the arm rest (in the pic you would look on the bottom of the arm rest from underneath where my cd case is) you will see some tabs that connect the arm rest to the door. pry them out.
4) at this point you should be able to pry out the arm rest from the door. The console trim will still be attached to the door but you will have access to underneath.
5) remove the pin connectors that connect to the switch.
6) looking underneath the console trim you will see that the switch is connected to the console trim via tiny phillips screws. The pic below has 3 screws (1 on the right side of the pic or front, 2 in the back). the other console trims only have 2 screws.
7) remove the screws with a tiny phillips screwdriver. you may have to pull up on the console trim to gain access to the other side (close to the door) but don't pull too hard.
8) remove the switch from the console.
9) now you should only see the console trim attached to the door by itself. moving the trim up and down (gently) you will notice that it is connected to the door by three clips. 1 clip is on the right side of the pic. it connects the trim to the black plastic door piece (you will see what i'm talking about). the other 2 are on the left and right ends facing the back. They connect the trim to the felt panel of the door.
10) looking under the trim, find the tabs. the one towards the back can be pryed out by pushing from the back outward (thats the easy one). The other two you will have to carefully insert your flathead between the console trim and the door and pry up (towards the roof).
Now you just have to do this for the other 3 doors
It sounds like a pain but it only took me 5 minutes of careful poking for each door. Not as bad as it sounds.
Any ?'s let me know.
  #52
Old 07-27-2006 | 08:56 AM
leonine's Avatar
Glad to be of service! Peace.
  #53
Old 07-27-2006 | 06:46 PM
koolkevin1107's Avatar
so what kinda paint did u use? did u clear coat it? how is it holdin up? im skeptical to paint that part b/c it's always gettin touched.
  #54
Old 07-27-2006 | 08:17 PM
Illusive's Avatar
I was worried about wear and tear too since it is in an area that is touched often, so I got it painted at a body shop with professional grade paint and clear coat. It costs a bit more, but it was well worth it IMO.
  #55
Old 07-27-2006 | 09:02 PM
dougiepants's Avatar
Avid FitFreak Poster
where are the pics of this stuff installed
  #56
Old 07-27-2006 | 09:19 PM
leonine's Avatar
Look up on the page and you will see it.
  #57
Old 07-27-2006 | 09:21 PM
leonine's Avatar
No problems. The paint is awesome. I have had them on for a week now and they have held up fine. No clearcoat. 4-5 coats with a 30 minute wait time between each one. Let cure overnight before re-assembly. You could certaintly prime first and clearcoat after if you wish. I didn't but that's just me.
Plasticoat Metal Flake part number #311
http://img91.imageshack.us/img91/8204/img1558by4.jpg
  #58
Old 07-28-2006 | 12:41 AM
I just saw it now and it turned out pretty good...
  #59
Old 07-28-2006 | 12:55 AM
leonine's Avatar
Post some pics; lets see how it looks.
  #60
Old 07-28-2006 | 01:27 AM
Master FitFreaker
looking good I got lazy so I bought my oem honda one for 60 bucks at my price hahaha
