[ASK]Need Help how to open A/C Panel
Here is how i did it:
1. There are 2 screws under the A/C controls. Take them out.
2. Pull off the panel under the A/C controls.
3. Pull open glove box, there will be three cables (used for A/C and venting). They are attached to little white posts. Squeeze the tabs on the end of the posts and slide off cables.
4. Use a SOFT panel removal tool. Like a plastic tool panel removal tool. Otherwise you will scratch and damage the dash. The radio will be hard to pull out the first couple times you take it out due to the clips that hold it in. There almost 10 clips holding it in.
NUMBER 4
it's so hard... the 2 bolts already opened..... so hard... very hard to open.... any idea???
