HID kit not working right.
Old 04-26-2009 | 05:34 AM
kroze's Avatar
My passenger side HID light go on instantly as soon as I turn the light on.
My driver side headlight flickered and then slowly turn on.
Is this a sign that the ballast or bulb is bad & need of a replacement?
Old 05-25-2009 | 03:30 PM
hidextra.com's Avatar
how long have you have the HID? it looks like you need a new bulb.
if the hid is used for more than 3 years, i might be time to get new bulbs.
you can contact directly if you have issue with your HID system.
Old 05-27-2009 | 02:51 PM
ReeSpeed's Avatar
Ive got the same problem....One light goes on immediately and the other goes on, then dims...then brightens back up. After like 30 seconds they are both the same brightness so I dont mind.
Old 05-27-2009 | 06:11 PM
713_fit's Avatar
check connections
disconnect and reconnect
SOMETIMES it works
shake the ballast too
Old 05-29-2009 | 12:24 AM
chrisng's Avatar
hmm i had a similiar problem, but i htink its b/c i dind't put hte connections in securely enough. try that
Old 05-29-2009 | 12:27 AM
mzfitt's Avatar
bulb might be burning out i had that problem not to long ago
with mine the passenger one would stay white instead of turning blue
until one day it starting turning off & i would have to shut off my lights & turn them back on.. & then it just died out
so u might need to replace. cus i did that & they been working since
madtodaimax
02-26-2014 05:22 PM
XenithXenons
47
01-09-2011 08:56 PM
samwell
06-10-2010 02:38 AM
kimo
06-17-2008 02:13 PM
SoccaBoi
10-18-2007 11:49 AM
