HID Problem
Old 11-09-2008 | 11:38 PM
artieman's Avatar
HID Problem
Installed HID kit and now my foglights wont turn on...is this a common issue? Havnt really felt like looking into the problem since the HID kit works fine...just figure i would ask before i pulled out the volt meter and started figuring out why...the kit was plug and play so im wondering if other plug and play kits had the same problem
Old 11-10-2008 | 02:14 PM
sevenaprils's Avatar
How do you install the HIDs? For me, I removed the front bumper so I could find good mounting spots for the ballasts. In doing so I had disconnected my fogs and forgot to reconnect one of them when I put it all back together so only one fog worked. If you do it this way check them out. Otherwise I'm not sure what else unless maybe you loosened the clips on the connectors just enough so they won't work?
Does your fog light indicator on your instrument cluster work?
As far is this being a common issue or not I don't believe it is. When I researched my HIDs and installing them I never came across anything about them interfering with the fogs. What kit are you using?
Old 11-10-2008 | 03:56 PM
azncarbos's Avatar
Check your wring probably mix the pos and neg around....when plugging bulb to ballast....
Old 11-10-2008 | 09:27 PM
artieman's Avatar
After reading the first reply i realized i made the dumb dumb mistake....forgot to plug the foglights back in when i put the bumper back on....thanks for the replies even though im just stupid...lol
Old 11-10-2008 | 11:15 PM
Rubba Burna's Avatar
HID Addict
well hey, took a reply to figure out what you did wrong
Old 11-10-2008 | 11:16 PM
artieman's Avatar
that and i was on my 5th or 6th??? beer by the time i put the bumper back on...im sure that helped out
Old 11-10-2008 | 11:52 PM
713_fit's Avatar
beer makes me work better =)
Old 11-12-2008 | 01:00 PM
gimme's Avatar
Administrator
ROFL! That was the first thing i thought of when I read this. I too forgot to do it this past weekend when installing side markers on another member's car.
DannyBoy8
03-08-2013 02:33 AM
mxl180
06-22-2010 06:27 PM
oneduduboy
08-31-2008 10:34 AM
sonicsc1
12-07-2007 05:13 PM
niugnip
30
05-19-2006 06:57 AM
