Front Park Lights and Signal Lights swap/switch rewire
I'm new to the modding scene. I'm mostly doing simple installs and just get someone else to do the bigger stuff. But this project I have in mind (after seeing Siphon's Winter Issue) of switching the park lights and the signal light has been bothering me. I want to see it done and I think it *may* look cool. Any advice on how that can be done? Any DIYs you know that this switch has been done with already?
Any help is much appreciated.
check out this website for the swap.
Having A Fit: How-To Guides
I'm not so sure about the reflector housing turning brown because those lights are swapped overseas. But I guess you could just change to a different bulb that doesn't emit as much heat.
I'm thinking LED bulbs would be my answer.
WhEreZmYFiT
25
03-21-2016 07:20 PM
90crxfreak
09-02-2010 01:38 AM
SCBarren
11-30-2009 11:21 PM
