Air Intake for 2006 Jazz GD3 L15a 1.5L VTEC Engine
hi guys, good day. i am new here in fitfreak and please to be part of jazz/fit forum....
i need your advise on which K&N air intake should i use that will be compatible on my 2006 jazz GD3 L15a 1.5L vtec engine.
i have done searching the net particularly K&N website but the closest information i have got is K&N 57-0602 which is for 1.4L only.
does this K&N 57-0602 is compatible with my car? and i noticed that there is an air temp sensor connected to the stock airbox of my car... does this K&N 57-0602 have a slot so that the air temp sensor can be connect to the new air intake pipe?
or any brand of air intake that would be compatible with my car?
Any suggestion from you guyz would be greatly appreciated...
thanks and cheers...
here are the photos of air temp sensor
Found this one but I do not have a GD3 I have a GE8 but has a model number that you could verify. Good luck.
Add 5.03 HP to 2007 and 2008 Honda Fit with K&N's Typhoon Air Intake System
Hi cjecpa, thanks for the info.. i am checking now the link you have given to me. I think this is the one for me, hopefully. i will research the compatibility of this K&N 69-1016-1TS to my car.. and get back to you soon..
Thanks very much.
Regards.. cheers..
Thanks very much.
Regards.. cheers..
Hi cjecpa,
I contacted K&N USA asking them for their recommendation on which air intake is compatible with car, unfortunately they doesn't have air intake that will fit with my need.. How sad it is..
Anyway, thanks for the response.
Regards
Regards
Hitman1614
53
06-12-2017 10:25 AM
Myxalplyx
09-23-2014 01:16 AM
avocado123
08-07-2014 07:35 AM
alabastersilverjazz
15
05-23-2008 09:49 PM
