J2534 Reflash Possibilities
Old 09-03-2009, 12:42 PM
Selden's Avatar
So, the TC-1 replaces the stock O2 sensor for dyno tuning? What are the two lower lines showing on the graph, and what changes do you expect with tuning?
Sorry for all the questions, but my introduction to engine tuning was during the era of points, condensers, and carburetors, and "data" consisted of reading the changing colors of a spark plug electrode as one experimented with different size jets and needles. Digital tuning of EFI engines is a whole new ballgame for me.
  #42
ev8siv3's Avatar
Please visit the Innovate Motorsports website for more information on the LC-1. I welded in a bung just after the flex joint on the stock exhaust to mount my sensor. On an N/A motor we can run 12.0-13.5:1 and still make decent power under load. We are measuring the amount of Air to Fuel in Lambda but converting it to AFR for a more visable curve.
  #43
Old 09-03-2009, 01:02 PM
Selden's Avatar
Thanks. Air-fuel ratio makes sense.
  #44
Old 09-03-2009, 05:36 PM
Daemione's Avatar
Awesome - I'm really impressed with your progress . . . Should open source reflash possibilities stem from your work, count on a respectable donation from me.
If the chip in the ECU is similar amongst all current 06+ Honda's we could be opening the door for the FIT, Civic, Accord, CR-V, Pilot, Element, S2000 and more.
What information would you need to determine the compatability of the '07 & '08 Fit ECU with what you're working on now? I'm spending my entire upcoming long weekend on misc. Fit projects, I could pull the ECU on my '07 & take a look . . .
  #45
Old 09-03-2009, 06:20 PM
ev8siv3's Avatar
if you can yank the ecu from under the hood and pop the cover off and take a high res picture that would be great. At least 1600x1200. Basically once we have a way to actively retrieve the ROM from the 2009 we'll see if the same methods work on the 06,07,08, and 2010 models.
  #46
Old 09-11-2009, 09:31 AM
ev8siv3's Avatar
Another quick update. I have managed to secure a K&N CAI and an HKS Hi-Power axle-back for the FIT. I will be installing the CAI first, then comparing datalogs to the originals to see how much the MAF and AFR readings are changed. Then I will add the axle-back to see if anything else changes as well.
I am also working with Epi (creator of EcuEdit) to add support for Honda 29-bit OBDII and extended parameter logging in the program for us. The graphs on the previous pages were generated using his program.
Once we have a kernel built, I should be able to retrieve the ROM and start analyzing it in IDA. If it uses a similar Renesas processor as in the Subaru/Mitsubishi world I should be able to find some maps fairly quickly.
Have a safe weekend everyone!
  #47
Old 09-11-2009, 10:55 AM
awptickes's Avatar
Awesome. If there's anything any of us can do, let us know.
What is the first part of the vin on the fit that you're doing this on (everything but unique chassis number)? How about part number of the ECU?
  #48
Old 09-11-2009, 11:11 AM
ev8siv3's Avatar
VIN is JHMGE8
ECU Part number is in the first post.
I could use hi-res pictures of the insides of the ECU and help identifying the EEPROM chips used inside ALL model years. I'm pretty sure the 07-08 used a different EEPROM than the 09-10. Either way, we should be able to access both. I could also use help finding the appropriate Data Sheets for the EEPROM once it has been successfully identified.
  #49
Old 09-11-2009, 11:41 AM
awptickes's Avatar
Originally Posted by ev8siv3
VIN is JHMGE8
JHMGE87279S03XXXX
Does that look like yours? I just don't want to take out my ECU and scan it for you if there's going to be nothing to gain by doing so.
I have a base MT.
  #50
Old 09-11-2009, 11:46 AM
ev8siv3's Avatar
JHMGE87469S07 - Fit Sport M/T
  #51
Old 09-11-2009, 12:59 PM
ev8siv3's Avatar
Anyone know how to open the case off the ECU? It appears to be more than just the 4 screws on the bottom and some prying.... Here are some pics:
  #52
Old 09-11-2009, 01:43 PM
awptickes's Avatar
I dunno, I was just going to remove all the screws and pry.
  #53
Old 09-11-2009, 01:53 PM
ev8siv3's Avatar
Let me know if that works for you as I haven't spent much time prying, just didn't seem to pop easily for me.
  #54
Old 09-11-2009, 02:38 PM
GOskateFL's Avatar
Originally Posted by awptickes
I have a feeling that the fit could benefit from some leaning out. I datalogged some of my autocross runs (although I still can't get the data off the iPhone, but it's good to review) and it seemed like it was running about a point richer than I would have liked.
Then again, when I tune engines, I don't factor in a "factory margin of error".
whats the deal with you iphone do you have an app for measuring those specs?
  #55
Old 09-11-2009, 03:08 PM
awptickes's Avatar
I use Rev and DashCmd. I've got a PLX Devices Kiwi Wifi for the link to the iPhone.
  #56
Old 09-11-2009, 05:12 PM
ev8siv3's Avatar
Well I got the K&N installed and a brief look at the AFR from driving real quick showed about .50 points richer, meaning a tune would really benefit the car now as WOT fueling is in the mid-11's now! Will try to get some datalogs this weekend.
  #57
Old 09-11-2009, 11:51 PM
ev8siv3's Avatar
Here is a quick 2nd gear run with timing and AFR. I added a new parameter called "Calc Load" which is what we've been using for subaru's for a while but this is calculated by taking (MAF * 60) / RPM, the value is then g/rev.
You can see that timing has jumped up a few degrees over the stock airbox runs, from around 19 to 22 which is great. The downside is that it's gulping fuel now which is wasteful. Up top is strange as well as it appears to be knocking, but it could also be the way that the mapping is on the stock ecu.. I'll try to reset the ecu later this weekend and get a fresh log.
  #58
Old 09-19-2009, 12:52 AM
Committobefit08's Avatar
Tagged for interest as well.
Ev8siv3 your a pioneer!
If its any help a fellow FitFreaker with a GE8 (Lek) said he just had ecu reflashed in Thailand. I don't think he did it himself but he might be able to give us some helpful information from who ever that did it for him.
Here is the thread he mentioned it in...
"I don't want to get to technical, but I had my car's ECU re-flashed, too and I get a lot more power and better MPG."
https://www.fitfreak.net/forums/2nd-...coilovers.html
  #59
Old 09-19-2009, 08:47 AM
FitStir's Avatar
*tagged for interest*
  #60
Old 09-19-2009, 10:53 AM
Lek's Avatar
Lek
Lek is offline
I just added a bit moe about ECU re-flashing, please scroll down the page.
Quick Reply: J2534 Reflash Possibilities
