Honda Fit Tuner Wing Fitment
Was thinking of getting this wing:
HondaFittuner.com :: Aero Styling :: Spoilers :: Spoon Replica Wing (fits 07-08 USDM HONDA FIT)
Anyone have it and can share if the fitment is good or not?
Thanks!
Thanks!
Yeah I was thinking of buying this as well but might have changed my mind to the carbon replica. I've heard you need to drill new holes but as far as that goes it should be pretty straight forward and Im sure they fit fine(per installer).
I pm Zangoose(sp?) since he have the wing. Fitment is pretty good and you do have to drill holes. Should be the same with the cf version. Unless you want to cut the bolts off and rely only on 3m double sided tape to hold the wing on.
i had the same wing and the fitment is excellent..and yes u have to drill holes just like anyother wing out there for the Fit excluding the kenstyle replica that hondafittuner sells that comes with 3mm tape.
eddykai
21
06-21-2006 03:46 PM
