carbon fiber roof
Old 09-21-2008 | 01:54 PM
kylerwho's Avatar
spoon fed
carbon fiber roof
I was looking and it seems like it could be a separate sheet of metal that is attached to the top of the car. is it possible to make a carbon fiber replacement of the gd3 roof?
Old 09-21-2008 | 08:21 PM
HONDAMATIC's Avatar
its welded and bonded on.. you cant just remove it
Old 09-21-2008 | 08:23 PM
kelsodeez's Avatar
UNBANABLE
spot welded onto the roof. it can be taken off by drilling out the spot welds.
Old 09-21-2008 | 08:49 PM
kylerwho's Avatar
spoon fed
spot welds are easily removed. any other way it is bonded to the roof? you could get a carbon sheet and screw it on where the old roof was as long as there is sufficient bracing.
Old 09-22-2008 | 03:46 PM
Tofuman's Avatar
they're called roof caps. i don't think anyone has made one for the Fit yet, but it could always be custom made ($$$).
Old 09-22-2008 | 03:49 PM
revd34's Avatar
or you can try carbon fiber stickers. i wouldn't want to screw anything into my roof unless its a spoiler into the hatch area
Old 09-22-2008 | 09:21 PM
kylerwho's Avatar
spoon fed
there is a company up here in seattle that does custom carbon fiber and fiber glass work. i should hit them up to see what it would cost. wonder how much weight will be reduced. 10lbs?
Old 09-22-2008 | 09:49 PM
PwRmAd's Avatar
It would add weight unless you actually replaced the roof. Or unless your talking about replacing only the top sheet metal layer. then it would barely save you any weight.
Old 09-22-2008 | 11:24 PM
kylerwho's Avatar
spoon fed
hmmm. need to find a fit skematic to see what could be replaced with carbon.
Old 09-23-2008 | 05:17 AM
Tofuman's Avatar
light weight wheels would be the most beneficial to performance. as far as body panels, maybe the front fenders. they are metal, it would take some of the weight off the front end to make the F/R weight balance a little better.
Old 09-23-2008 | 08:37 PM
kylerwho's Avatar
spoon fed
i think cutting weight off the top will help keep the weight toward the bottom to keep body roll even lower. But i just dont know how much weight will be saved.
Old 12-12-2009 | 12:35 PM
FITMugen's Avatar
09-10 honda fit carbon fiber roof top cover body kit
I just saw one on eBay but it was for GE8.
09-10 HONDA FIT CARBON FIBER ROOF TOP COVER BODY KIT:eBay Motors (item 250547114184 end time Jan-10-10 17:04:26 PST)
Old 12-12-2009 | 12:53 PM
dewthedew's Avatar
check out the pictures of the fit on hondapartscheap.com very helpful
Old 12-18-2009 | 04:35 PM
MNfit's Avatar
actually when I had hail damadge the roof was so heavily damaged they just replaced the whole skin, so it can be dont.
Old 12-18-2009 | 04:38 PM
HONDAMATIC's Avatar
yeah i know that but its still welded on.. so its not like you can pop it off at home and put a new one on
Old 12-18-2009 | 04:54 PM
JDMxGE8's Avatar
Yes it's possible to get a carbon roof cap or a replacement roof, but be prepared to pay mad money.
Old 12-21-2009 | 03:41 AM
qbmurderer13's Avatar
Cutting the roof off to replace it with a carbon fiber roof that weighs probably 3 pounds less... Really? Just take a crap before you drive.
Old 12-21-2009 | 01:31 PM
TurboManGT's Avatar
I lol'd
Old 12-21-2009 | 02:01 PM
dewthedew's Avatar
for real its a thin piece of metal.. it doesnt weight that much.
SixFootFiveFits
28
10-08-2013 11:56 PM
cjecpa
Upstate New York Community
08-15-2012 08:22 PM
jjeleven12
04-08-2011 12:55 AM
kelsodeez
09-15-2007 07:16 PM
