Getting a header coated???
Old 08-09-2007 | 08:34 AM
Wave's Avatar
Question Getting a header coated???
My original thread got me thinking...
https://www.fitfreak.net/forums/fit-...ification.html
and after reading this:
All About Header Wraps
Is it worth getting my brand new "stupid-expensive" J's Racing header sent out to be coated before I have it installed? I already got a price quote from Jet-Hot for $165 to have it done. What say you guys?
Old 08-09-2007 | 10:50 AM
JDMGD3's Avatar
Not sure if you have heard of Swaintech but I had heard about them a few years ago and they are known to be the best in the business when it comes to coatings. They can coat just about any mechanical part on a engine that is critical to the operation of an engine. They coat internals, bolt on pieces like intake and exhaust manifolds and even exhaust systems.
Swain Technology for engine piston coatings, race engine coatings, ceramic header coating, carbide metal coatings, thermal spray plasma coating, metalizing closures, spray welding
Check them out and see what you think.
Old 08-09-2007 | 11:04 AM
claymore's Avatar
Your post is interesting but the link is from a coating company here's the view from the other side:
material
faq
I have had the same header wrap on my Jazz for the past two years never removed and never one problem. And all my cars for the past 25 years all my cars with both regular and stainless steel headers again NEVER a problem of any kind. Problems come from poor installation you must follow directions.
Old 08-09-2007 | 03:45 PM
03DSM-RSX's Avatar
Frequent FitFreak Poster
Swaintech is by far the best thermal coating company in the business that uses the most durable materials (wont scratch off, you need to grind it to remove it). However, ppl mainly use them on turbo parts more than N/A b/c of the massive heat generated by turbos. I am using Swaintech coating on both of my boosted cars. Underhood temps and radiant heat were SIGNIFICANTLY reduced (measured via IAT logs). Before i have used Polydyn and Jet Hot, and those burned off within a month. THey dont have any good thermal insulation either. Swaintech, however, is not cheap.
I have a pic of swaintech vs. jethot if anyone's interested.
On a Jet hot coated pipe, you can burn urself by hovering your hand over it. With Swaintech, the heat is almost not there. (but dont touch it!!)
However, header/exhaust wraps can get job done very well as Claymore said. The rumor flying around is that wraps hold moisture when it gets wet and can cause the manifold to crack. i have yet to experience such claims on stainless steel material but most aftermarket header companies void warranties if header wraps are used on their header. If wrapping the header, all you need is to wrap the upper portion, as its least exposed to rain.
EDIT: Jethot quoted $165 for that header? Swaintech would be a tiny bit more expensive, if not the same price, but definitely worth it
Old 08-09-2007 | 10:35 PM
Jimmy101's Avatar
Thumbs up
Please post the pic on the jethot coating.
I have used their coatings before on a header
and was very happy, I could actually touch the headers
without burning myself.
THe headers were coated inside/out for $150!
Old 08-09-2007 | 10:45 PM
Wave's Avatar
Yeah, post it please.
Old 08-09-2007 | 11:22 PM
dank24's Avatar
I personally would not get a J's header coated. I want to see that thing after $600 haha.
here are some companies I heard and saw good things about. Here is a thread I was telling you about. after having the car turned off for 2-5 mins the guy was able to hold the header bare hand cause of the coating.
link to ephatch ephatch.com forum
Swain Technology for engine piston coatings, race engine coatings, ceramic header coating, carbide metal coatings, thermal spray plasma coating, metalizing closures, spray welding <link to company, the best if you are going to get it done.
edit: just saw he posted about that company, but from what I read they are one of the best.
Old 08-09-2007 | 11:44 PM
manxman's Avatar
Swain Technology is a very good "job shop" in the Thermal Spray Coatings field. Jet Hot's price is almost certainly for a Plasma-applied ceramic coating on the exterior only. The headers mentioned where you couldn't feel the expected heat close to the surface were coated inside and out. I spent 8 years as a sales engineer working for the company that actually started this industrial technology in the 1930's. The molybdenum coating that is standard on ALL piston rings in use in every internal combustion engine today was developed by this company, named Metco, Inc., now known as Sulzer/Metco headquartered in Switzerland.
If Wave's headers are expensive already, just wait for the bill for a one-off id/od ceramic coating, but once done, the header will be amazing and last forever. If you have the money, Wave, go for it. Every jet turbine engine in the world has around 4000 parts, and 3000 of them are made with a variety of coatings. Most metals melt at 2000 degrees F. or below. Jet engines have internal temperatures of up to 3000 degrees. Coatings like the ones you are considering make this possible.
Old 08-09-2007 | 11:51 PM
Wave's Avatar
Here's a copy of the quote from Jet-Hot:
We really appreciate your interest in JET-HOT. This is a follow-up to
our instant response to your inquiry. This e-mail has your PRICE
ESTIMATE and some technical information you need to have.
JET-HOT is the number one supplier of ceramic coated headers in
the world. We invented this coating and have over 20 years of
experience in the science of engine exhaust technologies. We also want
to let you know that we just sent you, by priority mail, information
that should help you make your decision. You should have this within a
few days. This packet contains several independent technical articles,
a JET-HOT 20 page brochure, and a video.
Technical benefits are as follows : Looks great, reduces
under-hood temperatures significantly and more, keeps pipes up to 40%+
cooler, Gives you 1-3% extra horsepower, extends average header life by
at least 10 times, and improves safety in an accident by reducing the
probability of fireballing.
We can coat almost anything you want including manifolds, oil pans,
springs, and a whole lot more!!!
The price to coat a 4cyl style header (no longer than 3ft) , in&out with
the sterling silver finish, is $165+s&h back. Add $20 for the flat
black,blue or grey finish. The NEW copper finish is also $20 more. The
NEW SEMI Gloss black finish is $50 more ( please note: the semi gloss
black part must be coated in&out).The SEMI Gloss black has a 1100F
temperature tolerance. We'll need them here for 3-5 days plus shipping
time back. The NEW SEMI Gloss black will take 8-10 days. If the parts
are chrome or nickel plated,add $40 to the total and 2 days for
stripping.I will send you our full information package to get you all
the coating benefits in greater detail.
Jet Hot also carries a coating called Jet Hot 2000. This coating runs up
to a temperature of 2400 degrees. It does NOT provide as much insulation
as the other coatings. The Jet Hot 2000 only comes in a flat black,blue
or grey finish and has a gritty texture on the outside. The Jet Hot 2000
runs $100 more than the sterling silver finish . This coating takes 3
days longer than the sterling silver process.We suggest Jet Hot 2000 for
set ups with nitro,turbos,etc.
Jet Hot has recently introduced some NEW coatings which are shown on the
web site. The newest is called EXTREME STERING (MC-15). The EXTREME
STERLING is a coating that is very similar to the Jet Hot 1300 sterling
silver but has a slight duller finish and has an orange peel look. The
texture of the coating isn't as smooth as the sterling silver, there is
some slight texture. This coating can handle 1450F without
discoloration (vs. the sterling silver which is 1300F). After 1450F, the
coating will become dull/grey but will not fail till 1700F. After 1700F,
the coating would blister/flake off(vs. sterling silver which fails
above 1300F). It has the same corrosion resistance as the sterling
silver. It slightly better insulation qualities than the sterling silver
coating. The Extreme Sterling coating will add $50 more than the 1300
sterling silver .
If you want to get the silver finish but are running high exhaust
temperatures, the Extreme Sterling is a good option.
The Extreme Sterling coating is a good option when running a turbo,
nitro, super charger, etc.
All parts receive a 3 year unlimited guarantee that covers chipping,
peeling, cracking, discoloration, rusting. New parts also get a
lifetime rust through warranty as well.
Please ship your parts to:
Jet Hot Coatings
5602 Orchard Rd
Pascagoula MS 39581
or
1840 West Drake Dr
Tempe AZ 85283
OR OUR NEW LOCATION
Jet Hot
2530 Milford Square Pike
Quakertown PA 18951
Please note: Jet Hot 2000 is only done in the Pascagoula,MS location
Just be sure to include your name and return info so we know who they
belong to and specify the finish of your choice. As for billing, you
can either include a credit card number with the parts or you can call
one in to the phone number listed below. Please feel free to call or
email with any other questions.
__________________________________________________ _____________________
Points to consider in making your decision are:
. JET-HOT has an impeccable reputation, unequaled quality and a
guarantee. A guarantee we stand behind.
. JET-HOT parent company Metallic Ceramic Coatings Inc, engineered
our coatings to the third generation which contains silver powders
allowing your components to look better, last longer, and outperform all
other coatings.
. JET-HOT uses expensive aluminum oxide to clean components. We
don't use sand like others.
. JET-HOT applies two exterior coatings and two interior coatings
and not just one layer as everyone else does.
. JET-HOT has the most brilliant appearance of any coating, not
just an ok or so-so look.
. JET-HOT will work with you to help you achieve your objectives
and will gladly provide you with technical know how at no additional
cost.
. JET-HOT has the most cost effective pricing and there are no
hidden charges.
$ SAVE 10% $
We are automobile and engine enthusiasts and want to insure your
complete satisfaction. Please review all your options. If you inform us
NOW that you intend to work with us when you are ready, we will give you
a 10% discount from the quoted price. Call or email us to lock in your
discount.
Our number is (800) 432-3379
YOUR FRIENDLY JET-HOT
TECHNICAL TEAM
Old 08-10-2007 | 02:13 AM
manxman's Avatar
Man, Plasma coatings for one-at-a-time work have come down a whole lot since my days in this industry. But then, I did not sell the service to the public, I sold, installed, and trained the techs. on the equipment.
I left the industry in '85, and at that time the prices in the quote would only have been applicable to the outside surface. The prices quoted will be justified by the performance of the coatings.
Old 08-10-2007 | 03:12 AM
dank24's Avatar
what company you think your gonna go with?
Old 08-10-2007 | 01:37 PM
manxman's Avatar
Wave,
BTW, the coating process that you are considering was invented by Metco, Inc. They were headquartered on Prospect Ave. in Westbury, LI, until Sulzer in Switzerland bought them out about 15 years ago.
Old 08-10-2007 | 01:49 PM
Wave's Avatar
Originally Posted by manxman
Wave,
Cool, I'm pretty close to Westbury, LI. They still located there?
Old 08-10-2007 | 02:07 PM
manxman's Avatar
I don't know. I left them in 1985 and have not had contact directly with them since. I would be very surprised if Metco were completely gone, but unfortunately through the last 15 years they lost their industry lead position. A lot of their less talented competitors who could only make cheap copies of the equipment and materials invented by Metco grabbed more market share through reduced prices.
The Plasma process invented by Metco makes an ionized gas stream that can make nearly the heat of the sun (gun gets to 30,000 degrees). Powdered metal, ceramic, or mixtures of both are injected into the "flame" by a secondary gas stream. The Plasma gun is as loud as a jet turbine engine (125 db), and can give the operator using it radiation burns from the light created by the gas stream.
The Plasma systems made by Sulzer to compete with Metco were absolute garbage quality, but Sulzer was still able to buy out Metco eventually and take over their patents.
Old 08-10-2007 | 04:21 PM
Wave's Avatar
So based on what you just typed can it be inferred that Jet-Hot is "pretty good"?
Old 08-10-2007 | 04:33 PM
manxman's Avatar
Yes- Swaintech and Jet Hot both use the same processes and many of the same materials. Jet Hot has specialized in engine parts, particularly headers. Swain seems to be involved in any and all engine parts. If you had a race engine and wanted to coat the top of your pistons with ceramic, I would go with Swain.
Old 08-10-2007 | 05:30 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Dont coat it.
Old 08-10-2007 | 05:56 PM
Wave's Avatar
Originally Posted by Mx6GT89
Dont coat it.
OK, why not?
Old 08-10-2007 | 06:27 PM
dank24's Avatar
I say go for it. You paid so much already, just go all out and get the beat money can buy
Posts in the NUUDE
Why are you going to? So you dont burn your hands on it and reduce temps a little? Why would you be touching it in the first place? Hahaha.
If you want to lower engine bay temps pull the rubber lining on the windshield wiper crowl. (Back of the hood) Its a simple mod many do.
I dont think its worth it. The header alone was expensive, why pay more money to ruin the sexiness of the header and gain nothing? Put the damn thing on and tell us about gains!!!
