2015 Exhaust Muffler Dimensions
Does anyone know what the 2015 Fit exhaust muffler dimensions are? I'm looking for the size on the muffler's piping inlet, the muffler outlet piping size and the placement of the muffler's inlet and outlet pipes relative to the muffler. Also, the muffler length and width size. Thanks!
Edit/Update -->
Been using Honda Parts Network. I found all the info I would want to know. Sharing in case you are looking.
Part Name: MUFFLER, EX.
Part Number: 18307-T5R-305
Honda Code: 9666855
Replaces Part: 18307-T5R-A51
In Your
Fit:
Exhaust Pipe - Muffler
Packaging Information
Dimensions Metric: 92.7cm x 30.5cm x 24.1cm
Dimensions US: 3ft 0.5in x 1ft 0.01in x 9.49in
Weight Metric: 4.027 kg
Weight US: 8.88 lb
Highlighted the muffler weight for personal reference. I may remove it altogether if it sounds good to me while testing. Using THIS thread as a reference to how a Fit sounds without a muffler.
Edit/Update -->
Honda Code: 9666855
In Your
Fit:
Weight US: 8.88 lb
exarchangel
14
09-01-2014 05:58 PM
pwnstar
11-14-2008 12:08 AM
