Apexi SAFC 2 for the jazz
hi guys
i ve been lurking around fitfreak for awhile now, i have learned alot about the Fit/Jazz thanks to all of u. I have a GD1, idsi 1.3 cvt, and i have recently installed my rims, tanabe springs, hks intake and i will be installing my borla exhaust very soon.
right now im getting my bodykit done, and i am hoping to get the Apexi SAFC 2.
wat do u guys think? cos i ve been doin some R&D and this SAFC improves ur cars performance.(well i hope it does)
i will post u guys a pic of my ride when it done
The GD3 uses only 12 valve until around 3800 rpm and then engages all 16 vlaves along with vtec. you are just not messing with vtec alone but the whole design of the motor and purpose of it...
I use on my L13A (GD1) a home made map module and the result is great, even if I have a constant % increase at all rpm
SAFC 2 should work best... cause you can modify the a/f ratio as you want; and the car needs it after the replacement of air filter, exhaust, cat etc...
Why don't?
Is it too expensive? Doesn't it give you lots of hp?
Really filter, pipings and big bore throttle body are different things....
You need to modify your a/f ratio after installing them.... to improve low rpm and to let your engine running near stechiometric again.
Remapping your ecu wolud be the best!! but safc 2 should help a lot...
Originally Posted by claymore
He was asking about the 1.3 ISDI not VTEC.
hi claymore
ur a bomb technician right? maybe u can help me out.. wat do u think? u think i can gain some extra hps on my mods
Originally Posted by alf74
Why don't?
thanks for the advice, dats exactly wat one of my friends told me, that SAFC would help increase in performance, but i just hope it doesnt damage anything in the engine or the ECU. i got my HKS filter already, i am installin custom headers and Borla exhaust. so im hopin to hook the SAFC 2 squeeze out more power out of my mods. i m just hoping for some good advice
Originally Posted by Super Spoon
Sorry to say, not worth it.
Go for a filter, pipings and big bore throttle body instead
pare!!
just to let u know im also planning on getting a big bore throttle body.. thanks to ur advice,
guys im a rookie a tuning i just started when i got my jazz and i started to learn more from all of u guys from Fitfreak
thanks for all ur comments and advices
Here's a tip pare ... everytime you install a performance item in your car,
disconnect the positive terminal of your battery. This will reset the mapping
of the ECU. The Jazz/Fit automatically adjusts to minor upgrades.
If you really wanna "squeeze" more power from your engine, use piggyback
ECUs. It's an INVESTMENT ! Like GReddy E-manage, Hondata and SMT.
I was also planning before to get an SAFC2, but top tuners here in the
P.I. told me that you wouldn't even feel a response of more power. If it's
relatively cheap, why not.
But add a few more thousand (pesos), I can already buy an SMT. So that's
what I'll invest on
It's still up to you thou, to each his own right Keep us posted
what I'll invest on
is it really that easy for some one doing minor up grades just have to disconnet the +terminal and the ECU will be remaped? i've got the FUJITA CAI installed for a few months now so should i just disconnet the battery to get the ECU remapped for better performance?
hey bro
so wat mods have u done to ur ride so far super spoon?, where can i get these piggyback ECUs, do u guys have em back home? how much does dat SMT cost or the Greddy E-manage? im pretty interested!
dude u got pics of ur ride and how u HP u have gained from ur mods?
tony2006
11-20-2008 12:15 AM
