Looking for near 130hp. What to do?
Old 04-15-2012 | 12:18 AM
Funkster's Avatar
Originally Posted by DOHCtor
I think you may mean decreased powertrain parts weight maybe? Decreasing a vehicule's weight isn't going to increase your power but only improve your Power to Weight Ratio! Ultimately, both increased power and decreased vehicule weight will improve performance but if you want to be quicker in a Fit, you'll want to shed lot's of weight (Removing my rear seats and spare tires gave me a half second improvement on the ¼ mile!), improve engine power (Biggest difference dollar per dollar is nitrous but you'll have to fill up the bottle once in a while and it may end up being costly! Plus a bigger exhaust and header is recommended because nitrous generates extra to lots of extra exhaust gazes volume!) or go with coilovers, bigger sway bars, unibody braces and sticky tires!
What i would do if i were you!
-Lighter wheels and tires!
-Denso IK20\22 or NGK BKR6E-IX plugs!
-Lightweight crank pulley!
-Shed weight!
-Cam and injectors!
-Save cash for Forced induction!
If you really want to do it the N\A way...
https://www.fitfreak.net/forums/fit-...ec-tuning.html
https://www.fitfreak.net/forums/fit-...40-hp-fit.html
Hope this helps!
Marko!
Pay attention to that 140HP thread. You will see his actual numbers were not even close to that.
Also for the record, I would say that .5 second difference was more than just the weight. A half a second is a ton of time and I have to believe would take more weight drop than that. You probably got a better launch, shift, etc.
Old 04-17-2012 | 12:57 AM
DOHCtor's Avatar
It's hard to get a better launch\shift with a 109hp Automatic Fit with 205-50R15 Nitto Neo Gen! Really, removing both rear seats and everything in the trunk shaved .5sec of my quarter mile times! Granted it's easier to shave .5 seconds off a 19sec car then the same off a 12 seconds car!
As for that 140Hp Fit, i think it's plausible as he got increased C\R, a ported head and a piggyback that allows him to increase ignition timing! The ports really are the main factor that explain why it won't make much power at the upper revs tough... Would be curious to see what he could get from a cam like those that cat cams offers!
Marko!
Old 04-17-2012 | 01:02 AM
Funkster's Avatar
Got any slips?
Old 04-17-2012 | 01:13 AM
Texas Coyote's Avatar
It's hard to get out of the hole with 205-50 16 Goodyear Eagle GTs with manual transmission and a mess of stuff going on under the hood....The rear seats are removed and it does get to scooting along a little better without them.
Old 04-17-2012 | 10:35 AM
DiamondStarMonsters's Avatar
Git you some 24.5" M&H slicks.
The only way a stock Fit is gonna cut a good 60' is if some BBC slams into you during his burnout.
Old 04-17-2012 | 03:08 PM
MNfit's Avatar
^^HAHA fucking win
Old 04-17-2012 | 04:10 PM
Funkster's Avatar
I hope you mean big block Chevy and not the other abbreviation.
Old 04-17-2012 | 04:56 PM
MNfit's Avatar
I have such a dirty mind, I dint even think big block chevy
Old 04-18-2012 | 02:21 AM
DOHCtor's Avatar
...would prefer a big block mopar!! eheheh
As for the slips, i sure got some lying around! Just have to find them!
Marko!
Old 04-18-2012 | 05:12 AM
kodok3ribu's Avatar
and that 140 (b/w?)hp car is mine. believe it or not, it's your right. but unless you can prove that my dyno is incorrectly calculating power than don't go hating my car.
but i do agree with the majority of people here though, that it is not economical to go for that power in NA compared to Turbo. And you also won't reach there by installing add-ons and definitely not by sheding weight. You shed weight to improve response and handling, not for adding power...
My motor is 7 years old now, but it only has around 28,000miles on it, due to the fact that it sits in garages most of the time and has been taken apart more often than a regular person owns cars in his life. Just next week, it will be taken apart again since it blows the seals again. So, go with DSM advice, and go Turbo if you still want to use your car as daily driver.
Old 04-23-2012 | 07:40 AM
kodok3ribu's Avatar
ok.. this is unimportant for you... but i'm just looking for a blow-off.....
today i was informed by my garage, that my motor has died.... and this time for good... my block crack, and the valves deformed.... So I will be looking for a younger brother to take up the challenge once again...
Still L15A, still NA, but with new target of 150hp... Wish me luck...
  #32
Old 04-23-2012 | 10:59 AM
Rough news.. try cementing the block halfway up the water jackets, perhaps.
It takes about a month for it to set up fully though. I've done this with street motors too, half and full-fill blocks.
To make 150whp NA you are going to need a bump in compression, good fuel and a big cam to name the major players.
You are doing this on the Dastek Q right? Very popular over there for the turbo guys too.
  #33
Old 04-24-2012 | 12:06 AM
kodok3ribu's Avatar
DSM, tks. But cementing won't do. I said crack just for simplicity. Actually the block disintegrate on the top of the block between the water jacket and cylinder. I have no idea how that could happen, especially since it's on the water jacket side. I'll post up some pics later tonight.
And yes, I'm looking at bisimoto cam, spring, retainer so I can get higher rpm. But it's a long way to go, since I'm going to be building a new motor. And I'm not going turbo
the pic:
  #34
Old 05-14-2012 | 11:06 PM
kodok3ribu's Avatar
Ok, just to update.. new motor has been rebuilt and mounted... currently running it slowly waiting for break-in.... wondering how much i can get from this new setup... i hope i can go past 145hp...
  #35
Old 09-22-2015 | 12:33 AM
space egg's Avatar
any update?
Stayfit07
03-09-2013 07:59 PM
Cordizzle4life
09-25-2012 01:24 PM
oshiri
04-06-2011 11:02 PM
08FitSport
02-28-2008 09:06 PM
xcurt15
33
11-01-2007 05:33 PM
