Strange hiccup or misfire
Hello fellow fitfreakers! So I have approximately 78k on my GD3 and I'm now getting strange hiccups and kicks during cold engine starts and coasting at 50-60mph with little gas on the throttle. I'm getting very concerned with this symptoms and not sure if I should push the car anymore than I should. I also think I'm losing power throughout the power band. By the way the car is an AT and when I put it to Sport mode and reach about 3-4k RPMs it starts to hiccup not due to the rev limited but something unusual. What can the problem be? I read that it could be due to a faulty coil pack, spark plug, ECU glitch, etc etc. One member said to take it to Pep Boys for a free diagnostic, which I did but the scan showed nothing. I'm afraid the car will just DIE or STALL while driving. No CEL on the gauge. Very very CONCERNED!!! I've check oil levels and it seems to be at the level its suppose to be at.
HELP ME!:confus ed:
HELP ME!:confus ed:
Hiccups or Misfire
I own a 2004 Honda Fit, it has1300cc engine which uses 8 plugs. I have come to notice that after a few thousand miles a, it starts to hiccup under a little pressure or just occasionally. All I did was change the plugs and it works fine thereafter.
I think i may still have bad coil over one of the plugs though, hope this helps
HELP ME!:confus ed:
HELP ME!:confus ed:
https://www.fitfreak.net/forums/fit-...d-stutter.html
try pulling out each coil pack, pack it with dialectric grease and put them back in. if this solves your problem, then its a coil pack. I have to do this and my car and it is fine, after a few thousand miles it'll get crappy again. i finally found the problem pack or i think it is... 3rd from left, or the second coil pack counting from the drivers side. that one, this time around had noticeable damage and discoloration; so i ordered a new one. we'll see if it goes away permanently
ikutoisahobo
10-02-2019 01:58 PM
Mr_Kunio
08-10-2011 12:33 AM
