Does anyone know about valves size of GE L15A7?
1. I would like to know about valve size which I may use from B16/B18/B20 or else to modify my car.
I just search that connecting rod for L15A7 is 89.4 mm which closely to Mitsubishi 4G93 DOHC 89.0 mm, it will make compression ratio drop from 10.4:1 to lower. I have a plan to modify L15A7 adding on custom turbo set (IHI VF28 Ball bearing turbo from Subaru Imprezza + HKS F con IS), too.
2. Does anyone have wiring diagram for L15A7's ECU?
If yes, please show me in here. Thank you so much for your kinding.
fluid
64
07-23-2014 10:03 AM
