Yes! more issues
Old 05-19-2010 | 03:34 PM
da9r00d's Avatar
im going to try a MAP Bypass Valve
Old 05-19-2010 | 04:40 PM
Texas Coyote's Avatar
I'm curious as to what kind of exhaust mods have been done to your cars that are having problems...
Old 05-19-2010 | 05:01 PM
OJRKraftWerks's Avatar
Former Vendor
I think most of MNFit's issues were cause by his AEM F/IC. I had a few conversations with the shop that was working on his car, and they told me they couldn't get the car to run with the AEM F/IC.
-Oscar Jr.
Old 05-19-2010 | 05:04 PM
da9r00d's Avatar
dc5-R Muffler, Full 60mm Cat Back. had before i Supercharged.
Old 05-19-2010 | 05:21 PM
MNfit's Avatar
I forgot about this thread. If I remember right I was having this issue just before I had the F/IC installed. The car then ran like complete crap and I got it switched back to the super card and the car has been running like a champ sense.
Old 05-19-2010 | 05:27 PM
I haven't had any problems in any way shape or form since I installed my supercharger... I waited to get the high boost kit since the literature I had read before getting the base kit stated that not to do exhaust modifications other than than a cat back and that is all my car has had done to the exhaust... I had noticed that there was a problem with the AEM F/IC from what I was reading here and even though I have one went with the high boost kit to get the Hondata reflash to avoid hassles..... The Jacksons had this kit in development for a long time and it works like it was OEM equipment if you just use it as is advised by them.... I am not for sure but I believe that I read that if you upgrade the injectors that exhaust changes will work.
Old 05-21-2010 | 04:10 AM
ku8o's Avatar
Originally Posted by FELIXY69
i love the plugs
and have also noticed problems with them when it's 2degrees celsius or lower (Vancouver Winter) at low rmp (2k-2.5k) it will notice it being a little rough....
now summer is here....the car drives so much better then other plugs
so the plugs runs very well on hot climate , but a bit problems on cold ...
it applied on turbo fit rite ???
im planning to use it as well
as i know,my daytime climate here is 34 degree celsius, while nighttime is round 19 degrees( on mountain area) ...
Old 05-21-2010 | 11:35 PM
da9r00d's Avatar
KraftWerks saved the day... They fixed my issue. it was the Supercard (My fault, i got it wet). they helped me out and they fixed it. car runs great. now im going to switch out to 10psi.
Big THANKS to OJ jr and OJ @ KraftWerks for helping me out. Best customer service by far from any company I've ever done business with
Old 05-22-2010 | 12:14 AM
Koi's Avatar
Koi
Supercard got wet and shortcircuited? Did they replace it with a new one and now it works fine?
Old 05-22-2010 | 04:29 AM
Was it the box with the vacuum line or the one with wires to the injectors?
Old 05-22-2010 | 05:52 PM
da9r00d's Avatar
they replaced it. it was the one for the injectors (which has a vacuum line on it)
RainierV
11-03-2018 06:54 AM
auralee
12-19-2017 04:13 PM
nzhorrorfan
03-15-2017 09:09 AM
greenmonster2420
10-22-2012 06:00 PM
SteveZ
03-05-2012 09:36 PM
Quick Reply: Yes! more issues
