replacement filter for mishimoto intake
So its time to replace my filter on my mishimoto intake due to its all rusty and nasty. I have been reading through KN's charts and i cant seem to find one the same size. Anyone replace theirs yet? Also anyone else have a problem with the filter rubbing on the factor intake mounting bracket?
My filter is still good with a bit of rusting.
Replacement wise you can go with any brand of conical filter.
Just make sure the inlet size is the same.
Only complain of rubbing I'm aware is with the radiator hose.
Replaced mine with a K&N. I used a 4" long one for a bit more flow and it barely fit. Got mine off of ebay from Summit Racing. There're others that are somewhat the same size as the one I use. There's one that's about the same size as the Mishimoto but inlet is only 2.75".
PN# KNN-RU-3700
Be forewarn it's a very tight fit.
I had to shove it as far back on the cf chamber as I could to get it to fit.
Don't get anything over 4" long.
Now I've to buy a new breather to match
A what on a what???
I was told it was a IAT, not a MAF. I want to design my own system, and need to know what the connection is also. I don't have the car here most of the time, so I can't just yank and check.
What year is your Fit. 2007-2009 GD 2010 --- GE. Or just pop your hood and look at your VIN number it will have GD or GE in the first part.
GD IAT slides in a rubber grommet friction fit.
GE MAF is held in with two screw fasteners.
GoFits
09-12-2010 09:54 AM
sLiVeRwOrM
03-28-2007 02:36 PM
