Test Pipe/Down Pipe ???
Old 08-08-2009 | 06:52 PM
setter11's Avatar
Is the Megan Down Pipe
MEGAN RACING 06-08 HONDA FIT STAINLESS STEEL DOWN PIPE TC body kits|Body kits|G35 Body kits|Mustang Hood|Civic F1 Fender
The only down pipe that is legal to use? is it even legal?
Old 08-08-2009 | 07:19 PM
JDMchris.com's Avatar
I run THIS
replacing your catalytic converter with anything else other than a catalytic converter is ILLEGAL.
Old 08-08-2009 | 09:45 PM
setter11's Avatar
What about this statement from the site:
(Bolded Area)
Megan Racing Resonators and Test Pipes offer the ultimate in high-flow performance. Offering substantial horsepower gains in the higher-end of the power band, the Megan Racing Test-Pipes are made of Stainless Steel with a quality polished finish. The Megan Racing Universal Resonators are also made of Stainless Steel and a straight through design, but serve to give your custom exhaust system a more mellow-deep tone while catering to traffic laws and regulations. (Note: The test-pipe is for off-road use only and is not intended for highway use. O2 Simulators may be required if a CEL is triggered.) - T-304 Stainless Steel - Direct Bolt-On.
i can read and see that is says off road use only, but that is said to cover there end of the transaction...
Old 08-08-2009 | 11:12 PM
dewthedew's Avatar
They mean its not as loud as a straight up cat delete because of the resanator in the pipe.
Old 08-13-2009 | 03:56 AM
setter11's Avatar
Installed aspec cat delete (sad sound)
So i installed the ASPEC Cat Delete and i have the ASPEC Axle Back...
i hate the Sound!!!!! its sounds disgusting!!!! starts off good, then when i accelerate TIN CAN!!! Popping and non sense... i will drive with it for the weekend, if i cant come around to the sound, im going back to my CAT...
**** IS there a way to quiet it down (RESONATOR)??? ****
** no one say the obvious and put the CAT back on**
**** Because if not i am going to have to buy the MEGAN one****
Wolfvision
06-17-2013 10:54 PM
FITdrummer13
03-21-2012 07:53 AM
SikxChoi
08-12-2011 12:29 AM
screwdgie
03-11-2011 09:08 AM
Polish
01-21-2009 09:26 AM
