AEM F/IC for 2008 Fit
I think its the same. I don't remember the company but there is someone who had a custom jumper harness built for the e-manage and fi/c could be done as well. I would strongly reccomend you don't hack into the factory harness. not worth being stuck under the glove box for hours when you can just clip one in and know your not going to run into soldering/connection issues and have to fault trace 20 different things at once. not worth the brain damage to save a couple hundred bucks.
The company that makes the custom harness for the Honda fit would be BOOMSLANG
I called them a couple of weeks ago to verify if there were any differences between 06-07-08 model cars....there seems to be no difference what so ever...however, they wanted me to buy a $90 repair manual, then scan a copy to them so they could work of the diagram...then they would decide what steps to take.
But.....I've confirmed with a local Honda dealer that the 06-07-08 are exactly the same. The harness runs over $200 but is worth the money spent
k24a2fit
04-17-2013 09:42 PM
BenjaminFit
17
08-18-2011 09:38 PM
explosivpotato
122
07-08-2011 08:44 PM
Kurse
12-08-2009 06:38 PM
