megan racing mid pipe anyone try it?
a few worm clamps would help raise the height at which the megan mid-pipe mounts. just pinch the hangars together by an inch and it should hide most of the low-hanging resonator. i wish i had known this before i sold mine
the megan mid-pipe is a few bucks cheaper than aspec's. as far as i can tell they're both the same design and both hang low. i went with the megan brand because i'm a cheap mother-effer.
for the OP.. PB blaster, get some! it'll make the job so much easier. WD40 won't do a thing to help loosen the exhaust nuts/bolts. after letting the PB blaster soak in for a few minutes i still managed to gash my knuckles removing the bolts near the cat., be careful in that area - hope you're not a bleeder
Ya I was planning on getting some clamps or fabbing/welding a custom bracket to weld to the underside of the car somewhere to hold it up higher. If I do that, though I might have to get some insulation to keep the heat from melting the carpet or something lol. I doubt it actually gets that hot, but I'm paranoid o_0
And x2 on the PB blaster. I had to use a LOT of it near the cat and a 36" breaker bar to loosen them sombitches up.
I pulled mines up as far as it could go without hitting anything and it's still noticable from the side. I'm actually gonna sell mines and put the oem back on. Less noise plus I can go lower without getting stuck lmao. I got stuck on an alignment machine once because of the resonator.
the gf drove the front passangers wheel over a curb and when it came down the curb hit the res... made an aweful noise. oh well Ill be removing the res and making it a striaght pipe when the s/c goes in.
nop not all... my drive way is so messed up that i actually bent the muffler which is back, and since in the winter i might have a turbo set up ill use it for the turbo ...
Earthmover84
07-22-2008 10:47 AM
dewthedew
05-29-2008 04:42 PM
michaelfit84
40
05-03-2007 03:33 AM
