how much can the AT handle?
Old 06-13-2009 | 10:27 AM
FELIXY69's Avatar
PLEASE GO WITH TRANNY COOLLLLERRRRR ~~ !!!
it is a must for AT....i don't have it yet...but i will get it ASAP !!
Old 06-14-2009 | 06:17 PM
jadr09fit's Avatar
^ Tranny cooler even if not boosted. Mine on the Buick keeps things nice and chilled. Even during the dog days of summer.
Plus Z-1 isn't the world's greatest ATF by a long shot.
Old 06-14-2009 | 06:43 PM
Texas Coyote's Avatar
I put a Transmission cooler on a GMC van and it even lowered the engine coolant temperature.... It is a must if you drive in heavy stop and go traffic, carry passengers or heavy loads, or just want your transmission to last longer.
Old 04-03-2010 | 11:17 PM
rocksnap's Avatar
Our AT Fits already have a cooler running thru the radiator. My 08' does anyhow. Though I won't complain adding an additional air to air cooler to any AT car.
Old 04-03-2010 | 11:29 PM
thefit09's Avatar
Where would one go about finding a trans cooler for an AT GE? How much would it run / how hard would the install be?
Old 04-03-2010 | 11:52 PM
rocksnap's Avatar
tranny oil cooler
Easy to install. I have put them in two of my other AT cars. Mount cooler in front of the radiator. Identify stock radiator in line and leave it alone. Run new line from stock radiator return line to new cooler in. New cooler return line back to stock return that would have normally come from the radiator return. This is called in series, or in line. You will probably need to buy a length of new cooler line to go from the new cooler out/return back to the tranny in/return.
This makes it also easy to change your tranny fluid. Disconnect one of the lines and run it into a one gallon clear plastic jug. Of course make sure you have the flow in the right direction.
Start the engine and run one gallon of fluid into it. Shut off engine. Refill one gallon into tranny, empty jug. Repeat until you have replaced as many gallons as your tranny capacity is.
Old 04-10-2010 | 01:52 AM
k-alt's Avatar
A/T dyno results 4.9.10
Just had my A/T dyno @4psi by Pineapple from FX Motorsports Development.
He tunes the FX NSX...and allot of other sick shit! He said the tranny was slipping on the last pull near top end.....need to just swap out for Manual.
Got to ~114 hp & ~114 ft. on stock exhaust and compression.
Old 04-10-2010 | 02:04 AM
The torque converter isn't going to lock at full throttle .
Old 04-20-2010 | 11:08 AM
rocksnap's Avatar
at
So this would be the reason the tranny was "slipping" at full throttle? Thinking of going with a KWSC but I don't want my tranny to grenade on me. I want longevity. Where can I find out the max torque these things will handle? Something tells me Honda didn't over design these tranny's a whole lot.
Old 05-21-2010 | 08:23 AM
ku8o's Avatar
guyz
i need info please
im using an A/T with T25 ar 42 turbo
currently using @5 psi for dailly driving
but when i rev it @ 5k up , it jumped on 7 psi
i already installed tranny cooler
is it safe ????
and what do you think about 'turbo blanket"
sounds good to cool down my engine bay
but somethin' bothers me
where does the heat goes ? since it only clothing not cooling ...
YeeFit
156
11-18-2011 05:12 AM
kelsodeez
76
01-18-2009 07:17 PM
whtsjdm
12-27-2008 04:31 PM
fitDSfield
08-16-2008 12:23 AM
gn-it&rn-it
14
04-11-2007 12:26 PM
Quick Reply: how much can the AT handle?
