Motor mounts for L15A to eliminate wheel hop?
Old 06-03-2009, 01:12 PM
Texas Coyote's Avatar
I had major wheel hop with the stock wheels and tires, I put stock size 195-55 x15 Continental Conti Pro Contact tires mounted on 9 1/2" lb Enkei Racing RPF1 7" wheels and it took care of the problem.... The weight of the stock wheel tire combination is the problem, not the motor mounts..... Even with a super charger, I have no more wheel hop..... As a bonus my car is smoother riding, acceleration, handling, traction, braking, stability in a straight line or high speed cornering and traction has improved on all surfaces..... I forgot to mention the improvement in fuel mileage.
Old 06-04-2009, 09:51 AM
NotraFit's Avatar
ok so wat stiffness do u guys recommend for the innovative mounts? have anyone here used it and do u like it?
Old 06-04-2009, 11:54 AM
trancedsailor's Avatar
I have EXTREME wheel hop in 1st gear. It's annoying when I want to merge quick, I look like a damn FOOL
Old 06-07-2009, 12:20 AM
wdb's Avatar
wdb
wdb is offline
Very interesting information! I have lightweight wheels sitting at my house right now, waiting for the tires and lugs to arrive. I'll have a setup similar to yours when I'm done; 10lb rims and 18lb tires. It should take about 6lbs off the stock wheel/tire setup.
I'll post up if the gawdawful wheelhop goes away after the changeover to the new rims/tires.
Old 06-08-2009, 10:11 PM
leonine's Avatar
I've had the prototypes on my car for close to 2 years. worth every penny especially now. I have 60A in the fronts and 75A in the rear. The rear mount takes the most beating so i got a stiffer one in the back.
Old 06-09-2009, 11:26 AM
Tofuman's Avatar
In theory - wouldn't a heavier wheel be more resistant to wheel hop than a lighter weight wheel?
Old 06-09-2009, 12:34 PM
The torque required to get a heavy wheel and tire moving is what causes the wind up of the entire drive train of front wheel drive cars...... The crankshaft,flywheel, transmission, C.V. joints, axles, brake disc, wheels, tires, and all related parts rotate across the width of the car causing the whole drive unit to overload and rebound as the tire bounces loose and repeats as the tire regains traction..... I had wheel hop problems with 60 H.P. VW Rabbit diesels in the early eighties because of heavy wheel tire combinations and destroyed struts, and C.V. joints in addition to killing what little performance that the little torque monsters produced.... If you are using sticky rubber compound racing slicks or racing tires you will probably need to change the motor mounts, but maybe not with street tires and wheels that are 6 or 8 Lb.s lighter in weight.
Old 06-09-2009, 12:48 PM
Tofuman's Avatar
^ That makes sense. Thanks for clearing it up. + rep.
fightinghamster
09-22-2016 03:20 PM
Owl
05-12-2016 12:49 PM
fit2bking
01-27-2016 01:10 AM
angryfit
98
02-24-2012 09:06 AM
808gd3
02-18-2011 04:48 PM
Quick Reply: Motor mounts for L15A to eliminate wheel hop?
