What happens to engine without TB?
Old 10-19-2008, 09:52 PM
jvm051's Avatar
Originally Posted by kylerwho
hmmm... im not to sure what electronic fuel injection has to do with the throttle body. throttle body lets air in and not fuel. sure they work off each other to know how much air or fuel to put in the motor but we are concerned with letting more air in at quicker rates.
And if you let more air in at quicker rates, you need more fuel, otherwise it will go lean. Maybe I should have said ECU changes instead of EFI, but since the computer runs all of it, it does have something to do with the TB otherwise it will not work in harmony together. You cannot just open the TB faster without changing fuel maps, otherwise the car runs lean.
Old 10-19-2008, 10:10 PM
CuTeBoi's Avatar
The reason I'm messing around with the TB is not to mess with the DBW system, just to know how the TB works...
I know that the DBW system requires many other parts of the system to operate properly. I'm just messing with the TB, and see what signals it requires to move and how it operates.
I'm trying to figure it out for the pupose of installing a DBW of my own on an old B or D series engine... just for the hell of it, and clean the engine bay up without having a big cable there for obvious reasons...
SOrry if people think I'm doing this for performance only, but it's for the learning experience of controlling individual components.
Old 10-19-2008, 11:15 PM
kylerwho's Avatar
spoon fed
i wonder what would happen if we turned the tb 90 degrees so that the butterfly opened horizontally rather than vertically. i was reading something about it in super street for their engine build in the castrol challenge. they are running itb's that open horizontally to reduce air turbulance. would this have any effect if we turned the stock tb sideways?
RogueCreature
06-07-2017 12:34 PM
Ultrawolf
05-25-2010 10:00 AM
gar1013
02-20-2008 12:43 PM
WrenInLA
27
09-24-2007 01:21 PM
MichaelBrown
54
08-21-2007 11:25 AM
Quick Reply: What happens to engine without TB?
