64mm Throttle Body
Old 08-26-2008 | 11:20 AM
jits14's Avatar
does the WR intake manifold have a largerer inlet diameter?
  #42
Old 08-26-2008 | 11:31 AM
Sugarphreak's Avatar
Push My Button
I don't think it does, but I will have an opportunity to verify that this weekend.
I was thinking even with the reducer you are going to experence a big increase in throttle responce as the computer will be letting in more air than it expects. 35% open on a 64mm opening is a lot more air than 35% open on your stock TB.
  #43
Old 08-26-2008 | 11:33 AM
Push My Button
Can somebody verify this will work on a USDM Fit
  #44
Old 08-26-2008 | 01:42 PM
Tofuman's Avatar
if this works... someone should produce a quality reducer. it might make the intake piping a tighter fit against the battery though.
  #45
Old 08-26-2008 | 01:53 PM
Pedalpusher's Avatar
You bring up some good points. Since our cars have no air flow meter, the computer won't know about the extra airflow. There is a very good chance of running lean. This might make the car feel crisp and might yield better gas mileage, but could damage the motor.
  #46
Old 08-26-2008 | 02:37 PM
Push My Button
Except near WOT because of the restriction going into the manifold would keep the flow the same as stock.
Probably the Blitz throttle controller is a better choice then unless you modify the manifold... now if that was only 75$ like the junked BMW TB
  #47
Old 08-26-2008 | 03:54 PM
Masterdebater's Avatar
if someone can give me the year and which bmws it comes off (not sure if someone did) then ill look into this
  #48
Old 08-26-2008 | 03:59 PM
thomasgrant's Avatar
2001+ E46s with the 2.5L
  #49
Old 08-26-2008 | 04:24 PM
alf74's Avatar
- This TB is perfect for stock intake manifold
- WR intake manifold can't have a larger inlet diameter!
- Intake piping doesn't hit battery even with 2cm TB spacer (I tryed)
- Air flow meter??!!! Jazz/Fit has a map or tmap sensor! The car anyway doesn't run lean with this TB
- Blitz throttle controller is a game of 300$ and WR intake manifold for 500$ isn't worth, in my opinion..
To be precise this TB is only 0.90mm/1 cm larger than intake manifold inlet diameter (I'm referring to interior side of TB, not 64mm exterior). I built this "reducer" to avoid air hit this cm!!!
  #50
Old 08-26-2008 | 05:17 PM
Push My Button
I am pretty sure the Fit uses a combination of the MAF and the 02 to do fuel adjustments. I have a feeling you would end up running way too lean, for the same reason I was running lean when I installed my intake manifold. you should run a check on your AF to see what it turns up.
BTW I can assure you the WR intake manifold is worth it I recently out-pulled an RSX with no problem with an extra 200lbs of gear on the back of the car (in a safe controlled environment in case anybody... especially mods were wondering)
I will measure the inlet diameter of the WR intake this weekend, also have an opportunity to measure the stock manifold tonight to verify the claim it is a 54mm opening.
  #51
Old 08-26-2008 | 05:46 PM
Tofuman's Avatar
the base model RSX, right? from a roll?
  #52
Old 08-26-2008 | 06:12 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Originally Posted by Injundon
2.5L Z3 and 2.5 and 3.0L Z4 all the same Part# : 13 54 7 502 445
the 64mm TB has nipples for coolant.
I looked this up and for 2002 the 2.5i has a different ending number 444 instead of 445.
  #53
Old 08-26-2008 | 06:16 PM
Posts in the NUUDE
This was not confirmed. That was my guess.
  #54
Old 08-26-2008 | 07:32 PM
Push My Button
Pretty sure it was a base, but was from a dead start and no RPM launch. I stayed ahead of him easily even with a shift. Those things must have outrageous RPM redlines because I was halfway through second before he shifted
Was just an interesting thing that happened, probably an novice driver or something.
  #55
Old 08-26-2008 | 07:42 PM
Posts in the NUUDE
The Type-S redlines at like 7800-8200rpms
Not sure what the base does. 6800rpms?
  #56
Old 08-26-2008 | 07:45 PM
jits14's Avatar
They are geared largein the 5spd, but they get through the gears almost as quick as a fit. He might not have been giving it wot.
  #57
Old 08-26-2008 | 07:58 PM
Posts in the NUUDE
Im sure he was. Bases are slow. :-/
  #58
Old 08-26-2008 | 08:08 PM
JamesBizzle's Avatar
wow... tagged for interest.
  #59
Old 08-26-2008 | 08:47 PM
Injundon's Avatar
if the plenum is ultimately 47mm all you will get is slightly quicker response and you'll have to use less pedal input for for the same airflow.
  #60
Old 08-26-2008 | 09:27 PM
jits14's Avatar
Based on some research on ebaymotors, it isn't this part model and corresponding bmw fitments. If you notice, the front looks a little different and the plug is different.
BMW 330i 01 - 05
BMW 330i 06 - 06 Cpe and Conv
BMW 530i 01 - 05
BMW X3 04 - 06 3.0L
BMW X5 01 - 01 3.0L
BMW X5 02 - 03 3.0L
BMW X5 04 - 06 3.0L
BMW Z3 01 - 02 3.0L
BMW Z4 03 - 05 3.0L
Our Part # : 337-60815-K70710
Our Inventory Notes : 3.0L,AT,RW
[IMG]file:///C:/DOCUME%7E1/ADMINI%7E1/LOCALS%7E1/Temp/moz-screenshot.jpg[/img]
the ebay picture could be wrong though...
It seems like its only the 2.5l one if someone can find a picture of it, but it might be a european version. I searched the bosch number the OP posted and it pulls up all european models like the alfa 156 and some audi models but its all in foreign languages.
Quick Reply: 64mm Throttle Body
