Bypass Valve
Bypass Valve
Are there any intake bypass valves offered for the Fit? I have an Injen CAI and it's been raining like crazy so I'm worried about hydrolock.
I'd also like any feedback as to whether the bypass valves are worth using.
are bypass valves worth using? how do they work?
i also saw something else that injen offered called a "hydroshield". it didn't seem like much more than putting a breathable tarp over the intake. do those work well?
the way the bypass vlave works is that there is a "cutout" if you will and a foampiece is added there that way if the intake sucks up water the water will spill out when it reaches that point.
i was reading instructions for install on AEM and they mentioned cutting pipes.
If i can find the vid, i'll post it.
jhass
04-21-2018 02:41 AM
theFITMASTER
01-13-2010 11:38 AM
WhEreZmYFiT
10-23-2007 08:40 AM
