jdm yellow fog lights
yeah i went w/ the film also. I actually did a whole writeup on how 2 install it so the film doesn't burn in the center like jamesbizzle said.
https://www.fitfreak.net/forums/fit-...s-answers.html
Hope it helps. BTW u gonna come 2 the meet 2nite?!
https://www.fitfreak.net/forums/cali...tml#post158534
I did the yellow bulbs. Way brighter than putting in film and the color was more solid. My friend did hers with the film, and I put our cars together and it was way lighter colored, more dispersed light, and wasn't as bright...
And it was only a 5 minute install: Pull out the 2 clips from the fender liner, bend the liner back, stick hand in behind fog light and remove bulb... put in yellow bulb, snap connector back on, and snap clips back onto liner... all I used was a flat head screwdriver to unclip the 2 clips.
It wasn't until afterwards that I was looking through the manual that it said to unscrew the screw beside the fog light in the front and the assembly can be taken out... should be even faster/easier... suckered
And those bulbs only cost 30 bux... (originally 65 on sale)
i used nokya 2500k hyper yellow H11. makes my hid's look awesome.
part #nok7618
and i got them at racing lab dot com.
makes me sad i have to take out my fog lights to fit the intercooler of the t1r turbo kit.
part #nok7618
Get PIAA plasma ION bulbs and you'll get that deep yellow look.
Do it:
CAR-GYM.com - Ultimate Lighting & Accessories Warehouse
Do it:
Do it:
Do it:
hmm... if so... looks like i'll to get me a pair of the PIAA's then, lol
thanx!
Yes, they will be brighter. If you get them, you won't regret it.
- You're welcome.
I have another set of H4 high beam set for my EP3... but forgot the name of that one... it was from Japan and it was 3k as well...
My sister's Fit has the 2.5k pair and they aren't as bright... a bit more darker yellow
Do it:
Do it:
Do it:
Do it:
