Fujita SRI and Idle relearn
Anybody with the fujita sri have to, or did, the idle relearn? just wondering since the t1r suggests it, but i was unclear on how exactly to do it, or if i even should with the fujita intake...
I just installed it tonight, and WOW its loud and deep...completely satisfied with it...pulls a little harder, nothing crazy, but i can notice...
yes, no matter hot/cold your fluid will come out because you are removing a soft line from the block...you are only replacing your stock hard lines because the coolant hard line gets in the way of the SRI...
just take off the stock line, plug the outlet with your finger, then install the rubber line...use cardboard under your car to catch any fluid...because if you don't cap it off with your finger it will spill everywhere...
Im not sure??? I just let my car run for a little while then drove it around, its a cool intake for now?
Luichenwai
17
07-23-2009 10:21 PM
AnlDyxp_GD3
12-27-2008 11:43 PM
gettinafit
27
06-07-2006 03:57 PM
