Header & full catback exhaust worth getting?
Just wanted to know if these were both worth getting? I don't want 2.5 inch piping on the exhasut because I don't want to lose performance. What size is the stock piping? Should I get the exhaust and keep the stock header? Or just get and axleback or get everything? Help!
Thank you for pointing that out but I was in a hurry this morning when I wrote that thread so SORRY if I didn't check to see if there was another thread on it. Plus there is not enough info on this forum to really get the answers I am looking for.
Why do I think I would lose power with a 2.5? Well lets see, you lose back pressure, something you need with a N/A car and not having certain internals like forged pistons and rods, cams and valvetrain or even a turbo there is no reason to have piping that big on this car because of the engine size. Now I could be wrong and if I am by all means correct me. I used to have a GSR integra so I know a little something about hondas. I have a suby now and am now getting back into the honda game so I am a little rusty.
Stock piping is 50mm. Skunk2 makes a 60mm system in addition to a 50mm, and like you've already brought up, they only really recommend the 60mm for FI setup and the like, so you're better off sticking with stock diameter for N/A in my opinion.
Whether they're worth it or not depends on a lot of things. What are you expecting to gain from making the mods?
Ok I am gettting an exhaust soon but don't know if I want an axle back or cat back. Should I go with 2.5 inch piping or stay with the stock piping size? Want to have good performance. Also here is a catback I found on ebay for $135.
eBay Motors: JDM N1 CATBACK MUFFLER EXHAUST SYSTEM 07 HONDA FIT NEW! (item 280118064167 end time May-30-07 16:50:13 PDT)
Ok I am gettting an exhaust soon but don't know if I want an axle back or cat back. Should I go with 2.5 inch piping or stay with the stock piping size? Also here is a catback I found on ebay for $135.
Now that we got that out of the way, if money is an issue, buy a good axleback first, then get the center-pipe to make it a catback later when you can afford it. You can do that with Spoon, J's, A-spec, Skunk2, and if you stay with the stock piping diameter then you can mix and match if you like -- i.e. Tanabe muffler w/ Spoon b-pipe. If your heart is absolutely set on 60mm (2.5") piping then the Skunk2 60mm setup is your only recourse, though unless you're planning on going FI soon it's a waste and will probably hurt your performance more than anything else.
Posts in the NUUDE
From what Ive header that listing is wrong. The piping is 2.25in; people have asked him.
And theres nothing wrong with that exhaust. Now what Id suggest is change the muffler. Do NOT use that muffler because Im sure its cheap and will sound cheap. Buy a nice axle-back to cap off the end. Im either going to get the exhaust listed above and use it as a Bpipe or the Megan.
Looked at the link... FUNK THAT! I got quoted $200 shipped for the Megan.
OMG i know you from IWSTI... im xfactorSTi on that forum... but yea choose your exhaust system well... be carefull how big you go with the size of the exhaust unless you get a AFC and richen the mix up a little or you will go lean.
Lol! It's a small world huh?
xorbe
06-09-2008 02:20 AM
bigtymer8700
15
03-18-2008 06:33 PM
explosivpotato
07-03-2007 08:35 PM
konradh
04-03-2007 02:17 AM
