Official Fit "lightweight" thread
#41
Originally Posted by Bounty Hunter
What did you end up doing for the tie down? It looks like that one in the link is for Vdubs. Does the OEM work well enough. Maybe some shorter "J" hooks would be needed is my guess.
#43
If your interested in using the stock battery tie down, one could just cut off the "J" part of the hook (and rebend the "J" with vice grips? I did! One could also buy 2 one inch long pipes/tubes that fits over the "J" hook thread. Mount the "J" hook to the tray. Put the tie bar on. Put the above 1" tubes on the "J" bar over the treads and then put the 10mm nut on.
#45
Update - Got the battery this morning but the posts on the battery look different from the stock battery in my car.
Do I need to get an adapter or conversion so that I can connect the battery terminals to the posts? Where can I get them?
#47
Originally Posted by lanakano
That's terrible! Do you have any pics of the posts?
I think I found something that'll work!
http://www.absak.com/catalog/product...roducts_id/592
#49
Found this pic at sojdm.com
Maybe they can help.
You might want to check out their Braille 6" J hook tie downs too. They're pretty cheap...
#52
Wave - you should be able to locate those terminal posts at most local auto parts stores. If not you can order them.
I will buy the battery myself but will wait until the factory one dies (in about a year or so).
#54
Passenger side rear seat weighs in at 28 Lbs.
Drivers side rear seat weighs in at 37.6 Lbs.
Weights include headrests.
So there's 65.6 Lbs if you don't plan on having more than 1 passenger.
Plus the 4 bolts so might as well say 66 Lbs.
If you take out the seat belts as well you may manage to bring that up to close to an even 70 Lbs.
Considering the 3rd seat belt in the roof by the hatch possibly a few pounds there that go unused. We'll see.
There's a start.
There's a start.
#55
There's a start.
There's a start.
Let's keep those weights coming in people. Anyway we can take weight of the front end would be the most beneficial.
#56
Pulled the seats out today and thought it was a first on the weight.
#57
You were the first. I updated the first post. LOL.
#58
i'm going to swap in the Braille battery that's in my AE86 to the Fit because the rolla doesn't get driven much. I hooked up the trickle charger but I just find it more practical in a car being driven more often. the honda battery is still tiny anyways.
#59
Ok, thought I overlooked it, just missed it entirely or was loosing my mind. Most likely suspect would be the the latter.
