AJR JDM Foot Light Installed
Thank You Ben give me the information to install the JDM Foot LIGHT
Here is couple step to install the Foot Light, Hope it helps you guys who want order it. I just give a few steps to you guys, because it is petty Plug and Play.
1. use a piece of cardboard or paper to draw the sharp of the light & the holder
2. Take off the undercover under the Glove Box & Wheel.
3. Put the cardboard or paper on the back of undercover
4. Drew two hole for the screw & light
5. than petty much follow Ben POST to plug in the wire
6. Turn on your KEY DONE
DRIVER Side
Passager Side
DRIVER Side
Passager Side
actually, what I did is not perfectly, buz I didn't have good hand. The light was not exactly at the center!! But it is looking great when it light up
Originally Posted by Yuf
So, how are the lights hooked up (eg, do they come on when you open the doors/dome light or are they hooked into the parking lights?)
This is the foot light KIT, so you don;t have to cut any wire you just plug the wire in the fuse box and it ready to go!!!
Go to the link below to check it out!!
https://www.fitfreak.net/forums/showthread.php?t=8781
chinkieboy
04-06-2012 10:49 PM
Jap 07 Fit
49
09-08-2007 07:05 PM
