Ignition Coil Stuttering
Hello all! I currently drive a 2007 Honda Fit Sport with over 120,000 miles on. Only problems out of the car so far have been well... nothing until now. I'll try to keep this short. Skipping on #4, coil had 5K more ohms of resistance than other 3. Plug on #4 showed some overheating. Replaced coil not plug. Skipping went away for a few days and came back. Got plugs and another coil to put on #4 because that is what the "worse" plug was on (overheated a little). So now with new plugs and new coil skipping is still apparent but the 2nd coil I got has 16.8k resistance compared to about 13-13.5k ohms on the other 3. I need some help here guys, please?
Look at that rather long Topic "Constant Speed Stutter"
OR
Start at the end and work backwards....
https://www.fitfreak.net/forums/1105918-post433.html
OR
![Popcorn](https://www.fitfreak.net/forums/images/smilies/popc1.gif)
120000, 2007, coil, driving, failure, fit, freak, honda, ignition, installation, instructions, miles, replacement, stutter, troubles
