Gen 1 wiperblades
Gen 1 wiperblades
My wiper are goners, could someone rec a good set? The oem made a lot of noise, id prefer better quality ones if they eist. A link or store would be great. Also, how do i know what size fit..?
I just replaced the blades on my '09 for the first time, with OEM that I bought cheap on eBay. You get 3 blades in the OEM replacement kit. The rear blade is the same LENGTH as the passenger blade, but it is thinner at the base where it slides into the metal wiper arm. The rear blade will fall out if it is put in the passenger wiper arm, and the passenger blade absolutely will not fit at all in the rear wiper arm. Just FYI.
kakrohn
05-07-2012 11:26 AM
