Dim headlights; high beams fine
My headlights randomly went dim, but my high beams still work. When I turn my headlights on, the high beam indicator also comes on. Google says I should check my ground, but I don't really know anything about cars so I'm not sure what to look for.
Is there a diagram I can take a look at? Or something else I should check? It's a 2011 base, if it matters.
Thanks!
Thanks!
If it's under warranty, bring it to the dealer, don't muck with it.
If it is intermittent, TAKE A PICTURE so the tech can see...both Normal and Dim.
Be sure to mention the high-beam indicator "on" (are you certain that's not just the regular Headlights On telltale? The instruments are always illuminated so Honda put that extra lamp in).
Wessy
05-13-2006 09:40 PM
