I tried Mobil One 5w-30, and....
Truth of the matter is that walmart never seems to have the mobil one 5w-20, so I purchased the 30 weight oil, adding it at 7200 miles. I know I am goint to recieve a scolding from a few for not obeying my american honda "bible", but overseas they are putting heavier oils in (an austrailian post comes to mind). Someone up North in Canada stated they have different oil weights too. Knowing this, I did the same.
Also, our car has been around for a few years, so it's not a new engine, and wasn't designed specifically for the US market and 5w-20 oil. Anyway, the point is this... the whole throttle responce seems to have tightened up and become more responsive. More than a few times I have had to check if I was in "S" mode versus "D" (which, for non sport auto owners is quite a difference in and of itself). I am not a huge fan of this car like some here, purchasing it for commuting only. I just wasn't expecting any difference from the oil change. Today, I am going up north, to the Lake! I will have a chance to check if there are any gas mileage concerns with this oil change too.
Has anyone else noticed any difference? What about you manual guys?
Luckily San Diego doesn't bear any extreme weather and we rarely or never exceed 100 degrees. A lot of people have reported that 5-30 usually shears down to 5-20 anyways so in the end it works out. I have posted on bobistheoilguy and with the good amount of response, it should give us an idea on what the more knowledgable oil crowd would do:
http://theoildrop.server101.com/ubb/...c;f=1;t=015624
After evaluating all the responses, I have decided to do my first change at 5,000 miles using Havoline (non synthetic) with supertech walmart filter. This will give the engine more time to break in further with the high moly content in Havoline's oil. I will probably then swap it out after 4,000k miles to Penzoil Platinum Synthetic 5-20 and Wix filter (napa gold) for another 5,000 miles. After that 5,000 miles with the Penzoil Platinum, I will send the oil in for an ****ysis to see if I can safely run it up to 7,500 miles. If so, I will continue to use that combination.
Andy
Andy
Andy
Andy
5w20 is recommended for "gas saving" by honda.. but if you actually look at the oil when it's changed, you will see that it's all crap looking when it comes out
i drive my fit quiet a bit on the highway and i do high revs, and the 5w50 just puts my mind at ease
-joe
-joe
Originally Posted by garett
that is interesting. is that all mobile 1 products?
did they actually recommend using penzoil? i have always heard nothing but bad things from penzoil, including from people that use to work there!
The factory fill is high in Moly content to coat the engine, that is why after my first 3,500 miles I am starting with Havoline 5-20 non-synthetic for about 4,000 miles. This will allow it to break in properly as intended before I switch to synthetic for maximum efficiency. Havoline has a LOT of moly and this will allow me put fresh oil while dumping out the old oil which will contain a lot of silicone that held the engine together when it was delivered as well as the metal shavings from engine break-in.
I don't see the point in using anything other than 5-20, unless your engine starts consuming more oil then normal. As for the engine, it is tiny and does not build up enough heat to really justify a thicker oil.
Originally Posted by sillypuddy
if you dont' think the little engine builds up enough heat.. just check your underhood temps after a run on the highway..
-joe
-joe
It's the stop and go driving, varying the engine speed that will heat up your engine. In fact your car will run hotter at idle than it will on the highway. That's why you will hear your fan switch on at idle if idling long enough. I don't think your fan even switches on during highway use unless of course you run the a/c.
they have honda brand synthetic.. but it's expensive
most dealers will let you bring our own, they will probably knock $5-10 off the price
-joe
-joe
i did this a few times.. after doing stop and go AND doing highway
you will notice that both your FENDERS get really hot.. as if the hot air gets trap there.. but not much under the hood
-joe
-joe
5W50 shouldn't put your mind at ease. The engine was designed to run a specific viscosity range (clearances and all). The 50 weight is outside of that range, so your engine is likely getting less lubrication. 5W30, 10W30 or 0W30 is ok, but don't go beyond that range. As far as the oil looking like crap when it comes out, oil always looks like crap when its be run for a while.
-joe
-joe
