Hella Supertones in a GE8...Please help!
Hey everyone, so after installing my Accord Low Horn as a replacement for the Meep Meep stock horn I am still desiring louder! So i went and ordered the Hella Supertones Dual horn kit.
I have no questions about wiring this up and getting them to work, but I do have some questions regarding mounting.
To either side of the latch mechanism there are black brackets secured to the radiator support with two bolts and then have a third bolt securing some sort of sensor that is attached to a wire harness.
What are these sensors and do you think it is safe to mount the horns off of these brackets, for instance if i remove the sensors temporarily to drill another hole to mount a bracket to attach my new horns to. This would allow the best placement of the horns but I don't want to set off my airbags or anything when removing these brackets or when the horn blows.
See the pictures below for reference to the bracket i speak of.
(Note: these are not my images, they are from other threads and i re-purposed them so i can show the placement of brackets.)
No one knows what these are??? Please help!
I looked through the entire ge8 esm and i cant find it anywhere and almost all illustrations are of the rhd model which uses a different front end so they are not there. Please help me out. thanks!
best guess is the impact sensors for the airbags.
personally, i'd just leave them alone and grab a couple of pieces of metal and make a new bracket and attach that to the current mounting point... actually, I think someone already did that.
That is what i was thinking, but i'd much rather use an existing bracket bolt instead of drilling extra holes into the rad support... I get the horns today, i will see what i can come up with and post later on.
So i finished installing the HELLA Supertones and they rock, i put the accord horn where the alarm horn was and it sounds great too, diddnt even need to remove my bumper.
i ended up drilling a hole on the left side basically in the same spot where the stock horn goes so that they would be symmetrical.
Here are some pics...(Sorry about the quality, they're from my phone)
I was looking at getting a pair of these. Any chance I could get further drilling and install instructions? Do they show through the grille at all? With my Black/Red scheme going on, I'd actually prefer that they did just a bit.
Thanks,
Indie
Thanks,
Indie
Damn we did this at the exact same time, I guess I had quit searching for install stuff when I was doing mine. Goobers was right. They are impact sensors (don't eff with em). I drilled into that brack where the stock horn was mounted. On the other side there was a indent in the metal almost symetrical with the original so i just drilled it out. I then put a hole in the seam above the horn but below the grill for the relay and it worked out perfectly.
Now for indie , I can email you pics or do a write up on the install on here what ever. It really wasnt that hard. Just a few female spade connectors, inline fuse holder, 12 gauge wire, and 30 amp fuse. I also had to get two bolts one the same size as the one holding the stock horn on and another smaller for the relay when i mounted it. Drilling wasn't that bad as long as you have a decent drill and bits. But like I said, i'll probably get the pictures up and do a write up since no one has done it in detail yet. If you have any questions feel free to PM me.
He didn't actually mention them exact,y but he did say something about setting off airbags so I shall give credit. I was thinking about doing the same thing he was, but wasn't risking deploying airbags so I just drilled it.
I have it mounted inside the bumper beam so elements can't get to it, just used a zip tie through the two holes in the metal support in the middle. I also drilled that same indent, its almost like it was meant for it.
I was also planning on doing a full write up but I need to take my grill off again to take better pictures, it was late and I was rushed when i finished the project so I didn't have time.
Indie if you can give me till tomorrow night or so. Java and I are gonna try and get our stuff together and combine it to get as good of a write up as possible. I just have a geology test tomorrow as well as some Autocad projects to finish . But hopefully sometime tomorrow night we should have something up and running.
Indie - have you bought them yet? or are you just feeling it out for when you do? If you haven't yet, I would say just pick up the set and by the time u get them, we will have this writeup done.
Thanks for the diagram but sadly I can only understand half of it lol oh well, to Google I go! Oh and do you mind giving me a list of extra things I may need to buy (wires, fuses, etc.) And also what tools am I gonna need( I'm more concerned about soldering lol do I have to do any of that?) And thanks a lot Java!
