Help! I am worried about fit!
hello,
I have a 2007 Honda Sport fit auto with 57,000 miles
The last few days I noticed that my engine service light was on
along with a thing that says
Service 123
and following with a negative number
like this -120 its up to -300 now keep going up
any help please dont have money to go to honda dealer and pay the crazy dio fees
sorry if this is the wrong forum
Service 123
Oil, Filter,Trans service. https://techinfo.honda.com/rjanisis/...606O00355A.pdf
Buy the filter at Walmart and https://www.fitfreak.net/forums/2nd-...30k-miles.html
The Maintenance minder was never reset. But you still need the trans service and filters (cabin,air cleaner filter)
They forgot to reset the oil change minder.... They may also forgotten to have changed the oil also.... I would take it back to them, put them on the spot and make them prove to you that they actually did perform the service that you were told they had... You can get a good idea if the oil was changed or not by checking the level on the dipstick.. If it smells burned or like gasoline, is not semi transparent, or feels like it has very slight gritty feel to it you need to raise hell with them.
The minus 120 or 300 are the miles past due that will keep accumulating until you have your maintenence minder reset. Whoever changed the oil should have reset it but looks like they failed to do it. Your owners mannual tells you how to reset it if you need it done. The same thing happened to me during my last oil change at walmart.
shudderbug
05-02-2010 04:39 PM
paramthegreat
12-11-2009 01:07 PM
