Has coil replacement fixed anyone's misfire/stutter?
#61
Yes, changed the plugs when I did the valve adjustment at 105k. Recently had the dealer pull the plugs and check them for fouling...everything ok.
New Update:: Ran my scangauge this morning. Could feel the car misfiring when cold. After about a minute check engine light blinked, idle went normal. CEL went off. Odd though, scangauge told me car remained in Open Loop for the entire drive to work ~ 45min.
Does anyone know typically when the ECM will switch to ClosedLoop?
#62
Crank sensor?
Anyone ever consider the crank position sensor? I don't have a Fit but my neighbor does and is having these exact symptoms.
I'm assuming there's no device (i.e. ignition control module) between the coils and the ecu. Right?
Possibly a grounding issue with the ecu? Maybe a bad harness that can cause a failure of the coils over extended periods of time?
Just thinking out loud here.
Cheers,
Cheers,
#63
Cheers,
Cheers,
1. if the crank sensor or other is at fault you find out quickly, if not suspect the coil paks and plugs. After all they do wear out (despite having no moving parts). And the checker TELLS that too.
2. As many posters attribute, replacing coil paks and plugs are major causes to cure stuttering and hesitation.
Guessing is no longer excuse for DIyers.
#64
I know all about pulling the codes, just haven't had an opportunity. I did however jumper the OBD2 plug to get the blink codes. 71,72,73 and the elusive 75. 71-74 are cylinder misfires. I couldn't find any info on 75. A general sense of malaise? haha
Mahout, I'm sure it's the coils, history is proving that to be the case most of the time. I just hate to think that Honda hasn't recalled these things. 50K miles should not be the life span of a coil. It's stupid, to be polite.
I'm going to swap #1 and #4 coils to see if we blow a 74 blink code. Does anyone have resistance numbers for these coils? What should they be on the primary and secondary windings?
Booya,
Booya,
#66
Random Multiple Cylinder Misfiring ( My Fix )
For the last few months I was getting a slight hesitation with my 2007 Honda Fit Sport, which became more and more frequent. The car has 80,000 miles on it and never had new plugs so I replaced them. After replacing the plugs and gapped them to.044 I thought I had resolved the problem. A few days later the car started to misfire badly, when I hooked up my OBD2 scanned it showed misfiring on all cylinders 1-4. I took out all my coil packs and found that the spark was riding down the coil boot and shorting out on the outside base of the plugs. (I could see a burnt looking discoloration at the base of the white part of the spark plugs) I tried cleaning all the boots and using dielectric grease but it only made it worse. I went to my local parts store and ordered a set of coil boots ($18 a piece) installed them on my existing coil packs, applied a little dielectric compound inside each coil boot, and reinstalled. Been driving it 2 weeks now, all codes have cleared and it's been running fine.
I asked around several different parts stores before I was able to find one that had coil boots, they didn't have them in stock or showed they had ever sold any but the called up their distributor and were able to get them ordered.
#69
I had the same problem at 93k miles. Replaced one but still had the problem. Then replace the remaining three and the solved the problem. I'm now at 139k miles and running strong. If you have to replace one, might as well replace all of them.
#70
I had the same problem, dealer could not fixed. See https://www.fitfreak.net/forums/1st-...c-problem.html
#71
glad I found this post
pretty sure I have the coil problem. car is stuttering under load (low rpm / high gear)
It feels like if I would be in 5th gear / 10 mph and flooring the throttle. but this happen at 50 mph / 5th gear.
Every time I accelerate more than half throttle at 2k rpm, the car is hesitating
I have no CEL and I don't want to change all 4 coils as they are costly.
Anyway to know which coil in problematic?
#72
If you have close to, or above, 50,000 miles you're probably right.
Several auto parts stores will check the codes for you at no cost.Howeever, you may get more than one coil 'bad' by code. While you're at it change all 4 plugs, too.
#75
i've been answered in another thread
You would want to look carefully at the coils, look for signs of arcing (electrical "tracks" on the outside), clean them and apply dielectric grease to reduce the possibility of a misfire.
#76
I have been reading in the forums and haven't found a clear answer as to whether coil replacement has been confirmed as the "solution" to the common engine stuttering issue (i.e. misfire at idle, worse with AC on, stopped in traffic)?
I realize this issue may be different on each car and could be various sensors, water in fuel, bad fuel, fuel pumps, fuel filters, locking torque converter issues, bad ground on the coils, etc...
That said, there seem to be a lot of people who suspect the coils as the cause. Has anyone had a stutter or misfire that they fixed by installing new coil packs?
Thanks!
Thanks!
Without checking work orders I believe we have replaced coils and plugs on at least a half dozen Fits and all solved the hesitaion they complained about.
you should be aware that plugs and coil packs are expendable items and a life of 50,000 miles is typical. A good OBDII check will show problems with coil packs and most aftermarket parts outlets wil perform that check for free as they should just as we do.
Its also why the most indispensible tool in the DIY toolbox is now the OBDII checker. For around $50 its a real bargain.
Its unfortunate that manufacturers decided to use coil packs; there's no good reason for manufacturers to decide their customers should spend $500 every 50,000 miles for just a tune up. spark plugs for $10, but not $100 per coil pack. plus the labor.
#77
Searching "coil replacement" resulted in 76 replies; the majority of whom agreed coil replacements solved stuttering and hesitation.
#78
also what do you think about this coils set on ebay
2007 2008 New Set of 4 Ignition Coil on Plug Coils Pack for Honda Fit 1 5L UF581 | eBay
150$ for 4 coils shipping included
#79
Yes. we often switch coil packs to recheck and sure enough the OBDFII knew it.
#80
Betcha we are all GLAD we don't run 12-cylinder Bentleys....
